1 - 20 of 29 Posts
Have a used 2012 3.5 Ecoboost crew cab with 60,300 miles. Purchased 6 mos. ago with 54,000 miles. Have a 1 year bumper-to-bumper warranty and a 2 year/100,000 year engine warranty. I have experienced the dreaded misfire shutter and loss of power (CAC issue). I am taking the truck next week in for diagnostic to local ford dealership. When I called Ford corp. about this they appeared clueless and did not know what I was talking about. After giving them my VIN, they stated no recall/TSB for particular VIN. Yet after searching not only this site by internet in general there are a few TSBs out there including TSB 14-0017 and 12-10-19. Are TSBs specific to VIN? Also, when the engine light come on (as when I experienced this issue last week), does the truck computer log this so it can be picked up by an OBD II scanner? If I hooked up a OBD II scanner as I was driving the truck would it give me a code that would be helpful to the mechanic? Thanks.
Yes, TSB's are usually linked to specific year models and VIN's.
Did your CEL (Check Engine Light) actually come on or was it the flashing wrench symbol? If it was the CEL, then it should have some sort of code stored. If it was the wrench, indicating that the truck went into 'limp-mode', then there probably won't be any stored information.
Did this happen randomly or when accelerating? Just asking as I had it happen twice on me last week driving to Chicago and I can’t get it to do it again. Both time were when I accelerated to pass on the highway.
I got flashing engine light and no codes were stored
My 2011 did it. Took it in dealer said it was a coil. I had coil and all 6 plugs replaced. Six months later it did it again, went to auto zone and rented diagnostic tool, it said cal 3 was misfiring so I replaced all the coils. It still had the problem so I replaced # 3 spark plug, it had a small crack, you could see carbon where the crack was. 6 mos later did it again, replaced all spark plugs. Runs fine. Problems started about 70000 miles. So first you see the wrench so accelerate really hard and it will start missing and the light will stay on so you can diagnose which cylinder it is. So now when I accelarate I can feel a vibration but only when put a load on it.??
That's why a catch can helps to keep all that PCV crap from fouling your spark plugs.
Love your sig.....do you actually own a 70' Torino?
Possibly one with the Semi Hemi 429 Boss (wishful thinking-lol)
drill the hole mod in the bottom of the IC.. worked for many
My 2011 Ecoboost S-Crew has the same issue but i have not seen the wrench or the CEL. Just a miss under normal throttle with a slight load on the engine. I have replaced plugs, drilled hole in the CAC, and I am thinking about coils. Dealer says all TSB's for this truck have been performed. I bought it used with 36000 on it and now have 75000. Not sure what to do at this point other than coils. What are the best ones to go with?
Stick with the Motorcraft COP's. And while you're in there, double-check the plugs that you replaced. It's pretty easy to crack the insulator and that could result in a misfire under load. ;)
Thank you for the response. I have looked at the Accel COP set but have not seen any reviews for them. I will check the plugs but i was very careful during installation not damage them or put too much pressure torquing them down. I have read all about the plug issues and did not want to cause further problems.
New member, so excuse me if this is covered elsewhere.
Just had the third instance of severe missfire with my truck of 94k miles. First time I could see carbon tracking. Second time, no tracking but a rusty brown material on porcelain between plug Base and boot. These plugs had only 10k miles. As I was rving in death valley, no auto parts in sight, so removed plugs, scraped off the material, regapped plugs, coated porcelain with diaelect grease, torqued plugs and drove out of the valley up 3000feet, under load, no missfire! No stored codes. I have had a hole in the IC for past 10k. Read the uses for this grease, might be the answer we're looking for.
Somewhere over the rainbow on one of the multitude of threads on this same subject there is a guy who had brown shzt on his plug bases and porcelain....acting same......his plug well seals were dried out and leaking....might be something to look at:cool: Use of dialetric may be interupting the path for current/short but is only hiding the symptom and not fixing the disease. Have fun.
These trucks just spit plugs out if you ask me, maybe due to the fuel being injected so close to the tip of the plugs. If all that carbon builds on our intake valves at least some of it is getting caked to our plugs. I usually try to change my plugs every other oil change and just consider it preventative maintenance. I have a 2012, 70,000 miles, no weep hole, tuned and holding 23lbs of boost through my rpm band and I've never had one instance of this misfire or CEL. It takes me longer to get my oil filter off usually then to swap plugs.
I know this is an older post but I'm starting to experience this with my 15 3.5L. I had some issues with it over fueling, running rough and pouring white smoke out of my exhaust. I replaced the plugs with NGK's and ran a can of 44K through it and it's been fine. The other morning on my way to work, I took off from a red light and all of a sudden the truck fell flat on its face, CEL started flashing and then the power came back and was fine the entire way to work. It has done it 5 more times since Monday, everytime it has stored codes for misfire on the entire drivers side of the motor. 4, 5, and 6, not sure if a cam or crank sensor is causing this or something else. Here is everything that was cleared on the truck when I scanned it.
164166
I have a 2015 3.5 with almost 67k miles. Never touched my spark plugs or coils. I have a upr catch can installed as well. Recently I noticed when I’m sitting idling I can feel my truck shake from the motor ever so slightly, and see a tiny bump on my rpm gauge. I figured this is a misfire but I don’t have any codes, check engines light, or any loss of power when I give her some throttle. Not sure if I should be concerned???
note: Catch can was installed maybe 4 to 5k miles ago
I know this is an older post but I'm starting to experience this with my 15 3.5L. I had some issues with it over fueling, running rough and pouring white smoke out of my exhaust. I replaced the plugs with NGK's and ran a can of 44K through it and it's been fine. The other morning on my way to work, I took off from a red light and all of a sudden the truck fell flat on its face, CEL started flashing and then the power came back and was fine the entire way to work. It has done it 5 more times since Monday, everytime it has stored codes for misfire on the entire drivers side of the motor. 4, 5, and 6, not sure if a cam or crank sensor is causing this or something else. Here is everything that was cleared on the truck when I scanned it. View attachment 164166
Hey I have a 13 3.5 doing a very similar thing but it's on the passenger side, cylinders 1 2 and 3. What was the result of yours and how did you fix it?
I just went through this exact thing with my truck less than 2 weeks again on a 2013 F-150. They ended up replacing the timing chain plus the added parts. Immediately after I added a JLC 3.0. I still believe that the major cause is the intercooler that builds up water, dirt and oil.
Actually, the major cause of the timing chain failure is stretching.
Soo... the timing chain gets damaged by water and crud in the intercooler? 🧐
I bought my truck used and it had some "unknown" tune on it. I bought it after the warranty expired and the timing chain was stretched by 70K. I wonder if the chains are just not built for the added torque/hp from a tune? I wish there were some heavy duty or performance alternatives for the chain. I think given the length, it's a little impossible to expect it won't stretch unless it's made out of titanium or something. I think I saw a calculation on here where someone said a 1/2" in chain stretch comes out to only .004" per link or something crazy like that.
1 - 20 of 29 Posts
