1 - 2 of 33 Posts
Mines not an eco but,,,,,,,i have 11 5.0 standard cab. I put aftermarket raptor parts on my truck. As far as 3.0s go…..these trucks are very large and heavy for 2.5's. i made a custom setup to run a king 2.5 x10'' single coil over on my truck. don't waste ur time. If your running a bypass also 2.5 would be fine, for me i wasn't so it didn't work so well. the fox 3.0 ℅ is now what i have and you can tell the difference in front end.
was easier for me with raptor parts so i could spend a little here and a lot there. couldn't really afford a lump sum kit……. if you don't want to change your upper coil bucket for future going back to stock option.
no King 2.5 x10''…….i was answering your question that 2.5's single handedly IMO don't work well with the raptor setup. Im running fox 3.0 raptor shocks by themselves. and work good. Im still saving for bypass up front. I'm not sure about dirt freak kits they run a single 2.5 but look to have dif shock angles than raptor stuff. If i was to buy a kit i would buy something with dual shocks up front. don't waste ur time. Raptor stuff works well on our trucks, problem is the a/m stuff is best and it has quite a bit of tax on it. lol.
BTW that picture is 4k in parts for complete front end.(complete full tie rods not add on couplings some kits provide) some stuff you can get cheaper now that the trucks been out. its a budget , build as you go setup. ill try to get some pictures of how it is now w fox 3.0s
1 - 2 of 33 Posts
