So we've all seen what the catch can is able to catch from the pcv system before it enters back into your intake
by not having a catch can your intake valves can look like this pic below
obviously a catch can would help significantly reduce the amount of sludge entering into the intake, however if you decided to install a catch can @ 50k miles your intake tract and valves would more than likely have an abundance of carbon build. you will need to have a shop manually clean your valves with wire brushes.
In my 2011 Ecoboost with 55k, completely stock, it's starting to idle rough until it's at operating temp then it runs smooth. I believe this is because I may have a few cylinders with an abundance of build up on the intake valves causing the rough idle until operating temp.
Ford doesn't currently suggest a way to clean your intake tract and valves and doesn't recommend seafoam as it could damage your turbos and void your warranty.
My suggestion to clean your intake tract and keep it clean would be to install a water/meth injection kit. This would basically steam clean the deposits off your intake tract, intake valves and tops of your pistons.
so guys tell me, is this a safe option to clean my intake tract and keep it clean?
I picked up a boroscope from harbor freight and as soon as it's in ill do a write up on what my intake and valves look like. I put on a catch can at 40k miles.
I wonder if I rig up my shop vac with a small hose if it would suck the carbon off of the valves while I spray some sort cleaner on them?
My next mod is an AEM water/meth system. But that is a little while down the road. I just got my exhaust,170* thermostat and sct x4 with custom tunes from 5*. So I'm not buying anything for a little while.
Best is a manual cleaning.....and meth/water inj will help slightly, but would need to be sprayed constantly to do more.
It is really only a 3 hour or so job to remove the IM and do a manual cleaning, and a few on here have done them and may help. I can give you step by step as well.
You say it will help slightly but will need to be sprayed constantly to "clean" more. What's your thougts on long term use. Wouldn't it eventually clean it all overtime and then continued use would keep the engine clean?
I know this is my opinion, but the "steam cleaning" effect doesnt really come into play until combustion, and is minimal to say the least. I dont know about you guys, but i have always had a tough time trying to clean carbon down an intake port. My most effective method is head disassembly. That gunk is really stuck on there, and i feel that the misfire problems are valve to seat sealing troubles. Cleaning that area of the valve is just about impossible. I wish i had a better answer, the local BG guy tries to sell a 3 part system for DI engines, but most customers can't take the idea of $60-70+ added to an oil change. How many mile oil changes do you shoot for? I go for about 4K, 5-30 is cheap compared to some euro cars.
Couldnt you do a motorvac? When it comes to the intake cleaner, do it in a couple steps. Before you start and while its running and use double the amount.
The rate of build up far exceeds the cleaning ability. It does help, but the amount is minimal. If you prevent it all from entering in the first place then, then it is a non issue.
pretty correct here. The Ecoboost and most engines now days the manual cleaning is very effective. Here are some pics:
Ecoboost at only 30k miles before and after manual cleaning:
So the manual cleaning works extremely well, and is not that difficult. True, disassembly is always the best, but these results are close. I would no do solvent based cleanings after we have seen the turbo blades damaged from the debris impacting them that is broken loose from the use, and solvent never gets it all unless you do it from early on on a regular basis as BG did in their test. Then your causing premature wear and damage to the cylinder walls and pistons as a portion always is forced down between the piston and cylinder wall during the process, and these deposits can be carbon rock hard and very abrasive.
We see a few causes of the misfire. Rough idle and running is mainly the buildup along the seat and valve lip/edge that causes vortices and uneven air flow in at idle and low RPM's (higher RPMs the flow overcomes this when the deposits are not that severe), spark blow out from the liquid mix ingested from the CAC due to the PCV system flaw, and as you describe, when severe coking, valves can actually stick, or if a deposit breaks loose that is big enough, get caught between the valve and the seat. Also when coking is severe the air entering each cylinder is an uneven amount and that messes everything up.
That would loosen and remove a good amount, but the damage I described above occurs, so it is at the sacrifice of engine longevity. Never good to do any solvent based cleaning on a turbo application.
Harbor freight sells a media blaster that will blast walnut shells. How difficult of a job is this for someone that has never done it before? It seems like all you have to do is make sure you have a vacuum line in there while you blast.
Just for clarification TB pirated this picture from me! Lol! This was done with a mechanical scrub, using Amsoil Power Foam, a bottle brush, and a shop vac while rolling the engine over by hand to close the valves.
So you were able to turn the crank by hand to close the valves.
Did use a brush with nylon or brass bristles?
My truck is a 2011 with 43k miles on it. Only the last three are with a can.
Did you clean your intake manifold too?
