Element Fire E50 Fire Extinguisher
Highlights:
E50 Professional Element Fire extinguisher is the most popular model, offering 50 seconds of firefighting protection this lightweight extinguisher has more than 4X a standard 5lb fire extinguisher. E50 makes no mess and leaves no residue, it's non-toxic, non-corrosive, and environmentally friendly means this fire extinguisher will not remove breathing oxygen in confined spaces. Internationally tested and certified, the small construction is weatherproof and unaffected by extreme temperatures (-140F to +320F), humidity, movement and it?s also safe to store in wet environments and will not expire.
Compact and Easy to Use
The solid construction means there are no moving parts or compressed gas to be serviced. The zero-pressure discharge creates no trust and will not spread oil and liquid fires. It?s easy 4-step activation will fight all major fire classes A, B, C, and K. Simply remove the top protection cap. Hold from the black plastic handle and remove bottom striker. Strike the tip of the yellow striker along the tip of the red Element unit. This will start a chemical reaction and gas will immediately begin to flow from the tip of the Element extinguisher. Hold from the black plastic handle and point the flowing gas to the base of the fire until extinguished.
Packaging Includes:
Highlights:
- 50 Second Discharge
- Compact and Easy to use
- Use on A, B, C, and K fire classes
- Leaves no mess or residue, making it eco-friendly
- Non-toxic and non-corrosive
- Zero pressure discharge will not spread the fire
- Maintenance Free no moving parts or compressed gas to service
- Completely weatherproof will withstand extreme temperatures
- Will not expire
Packaging Includes:
- E50 extinguisher with high visibility striker and cap
- One mounting clip
