Keep in mind the ecoboost in winter conditions will catch this much in the average week of driving. If running a small can, you are already most likely having a good deal of what is in there being pulled right through and into the engine during high condensation weather (cold weather).
Here is what is caught in one week in Florida here with temps in the 40's at night, 60-70's day. This is of course from a system with app 1 qt capacity and designed for the amount of PCV compounds the ecoboost puts through the PCV system:
The different levels will contain from the bottom up:
Water with sulfuric acid (can eat through a red solo cup, use a glass or a material a water bottle is made from)
Unburn't fuel and various hydrocarbon compounds
Emulsified water oil fuel mixture
Oil that has separated and floats on the top.
If you smell this caustic mix you can detect alot of what a good can has caught and trapped VS where most let a good amount pull right through the can catching a minimal amount of what is actually part of the combustion byproduct and related processes. You want NONE of this entering the intake air charge, and anyone in doubt on any can they care using, simply stop into any auto parts store and pick up a clear glass inline fuel filter (not the plastic ones) and install it between your cans outlet and the intake manifold vacuum barb. Now drive 50-100 miles and see if it is already saturated in this oil and gunk getting past the can you have chosen. Works with all cans and shows you up close an personal if the can you have installed is letting this stuff past and only catching part of it, or is properly designed and of the minimal size needed to catch all of it.
You need to know first hand what is happening with your engine as none of this gunk is good to be ingesting into your intake air charge, especially with a turbo or other FI application.
