You've had 2 timing chains replaced on your 18 King Ranch?My truck has the same problem as described here. Did not start the overheating till after the second timing chain replacement. Towed a 24ft car trailer over 18,000 miles and never got a high temp. Now towing the trailer empty the temp stay up on the 230-235 range half the time.
The dealer change the water pump and thermostat and on the way home I got the temp spike again. Going back to the dealer again for this.
I’d be amazed if the dealer performed this ^^^More than a flush. It would be dropped into a tank of chemicals and the bath would dissolve the corrosion internally.
Keep in mind that radiators weren't aluminum back then. So honestly, I don't know what the equivalent procedure today would be. Or if there is an equivalent.
I just googled the term and like many things "southern", we were not pronouncing the proper word correctly. The Word was "rodding"? Lol
Agreed!I’d be amazed if the dealer performed this ^^^
Mechanics got to get to work too.You let the dealership drive your truck over 70 miles, that's a heck of a road test.
Pick up some groceries, kids, go do some sightseeing.Mechanics got to get to work too.![]()
Hey yall. I'm looking for some advice. I recently purchased a certified pre-owned 2017 Ford F150 3.5L EcoBoost with 50,000 miles and I am noticing the engine temp running hot and causing the fans to kick on. I took it to the dealer and they checked for coolant leaks but did not find any. I have noticed that the engine temperature gauge begins to display the current temperature above 226 degrees. Apon accelerating up to highway speeds (80mph in SD) and after cresting a hill the temperature gauge reads 230-236 degrees. It usually disappears after 30-60 seconds however, after getting off the highway I can hear the fans blowing full blast. I only notice the temperature reading up in the 230's after accelerating to 80 mph or after cresting a hill. This happens regardless of having the AC or heat on and I am not toeing anything. This is my first ford truck and I am not sure if this is normal or if something is wrong. Any ideas on what is going on?
I have the same problem. So far it has a new intercooler, radiator, water pump, thermostat, head gaskets, new turbos. I have disconnected louvers. Still runs hot! It's a 2015 F150 4x4 King Ranch. I'm seriously at my wits end.Hey yall. I'm looking for some advice. I recently purchased a certified pre-owned 2017 Ford F150 3.5L EcoBoost with 50,000 miles and I am noticing the engine temp running hot and causing the fans to kick on. I took it to the dealer and they checked for coolant leaks but did not find any. I have noticed that the engine temperature gauge begins to display the current temperature above 226 degrees. Apon accelerating up to highway speeds (80mph in SD) and after cresting a hill the temperature gauge reads 230-236 degrees. It usually disappears after 30-60 seconds however, after getting off the highway I can hear the fans blowing full blast. I only notice the temperature reading up in the 230's after accelerating to 80 mph or after cresting a hill. This happens regardless of having the AC or heat on and I am not toeing anything. This is my first ford truck and I am not sure if this is normal or if something is wrong. Any ideas on what is going on?
I changed my temp senor and it did nothingChange out the temp sensor ?
It never ceases to amaze me what these dealers will call “normal”. I swear they want your engine to blow. Your definitely not crazy, I’ve never seen temps that high just cruising at any ambient temp. Highest temp I’ve ever seen on my NGauge was 227 and that was after wringing out the engine a few times on the highway, I’m talking approaching or exceeding 100mph and turbos screaming along at 21psi. Even 227 had me nervous and I backed off. I’m told they go into limp mode at 250 degrees, anything close to 230’s or higher seems like cutting way too close for me.View attachment 171748
2018 F150 Lariat 3.5 ECO Boost
Outside temperature was 45 F. Called Palmetto Ford in Charleston, SC and the head of the service department called this “normal” 10th Gear at 2,000 RPMs???
I’m going to visit the dealer again and suggest they start by looking to see if the radiator inlet/ outlets are blocked with debris from the radiator.
Sounds like this has been a very common occurrence?
Yes the temperature sensor was changed about 2 months ago.Change out the temp sensor ?
