America's best-selling truck deserves to have the best and today we'd like to introduce you something truly amazing - Morimoto XB™ Black Sequential DRL Bar Projector LED Headlights. This pair of headlights will set your truck apart from the crowd and make people stare at it every time you drive by.
Stunning quad LED optics with bright diamond white LED bulbs and beautiful sequential DRL bar are the key elements of this model. They produce a well-defined beam pattern with a great amount of width, intensity, and a proper distribution of light no matter where your truck is headed to. These headlights are designed for 2018 + Ford F-150 models and now they are available for Pre-Order at CARiD.
Morimoto® - XB™ Black Sequential DRL Bar Projector LED Headlights
Features:
- Good for 2018 + Ford F-150 models
- Include 2 Headlights and XB LED Driver Modules
- Bulb type: Osram Ostar LED for Headlights and DRL
- Color temperature: 5500K (pure white)
- Color temperature (DRL): 5000K
- Raw lumens (per headlight): 2600
- Lens material: UV-coated polycarbonate
- Housing material: PPS plastic
- LED optics: Kuria Quad optics
- DOT, ECE, SAE, FMVSS compliance
- IP67 waterproof
- Connector: Ford multi-pin.
Morimoto™ | LED Fog Lights, HID Projectors, Bulbs — CARiD.com
If you want your Ford to stand out and enhance the visibility at the same time - Morimoto XB™ Black Sequential DRL Bar Projector LED Headlights will be your best bet!
Features:
- IP67 waterproof
