So our trucks have 3 inch mandrel bent exhaust from the factory. Not too shabby but I'm wondering what the factory muffler is like. Is it chambered or flow through?
I'm thinking of just cutting out the stock on and throwing a dynomax ultraflow 3" in there. anybody have any pics of the stock muffler and resonators on the inside?
Update:
1. the stock muffler is a straight through design
2. the stock resonator is a straight through design
3. the muffler is a 2.5 in 3" out
4. the resonator is 2.5 from the catback flange to the muffler
5. the stock y pipe ends with a 3.25" pipe after the cat going to the flange
6. the stock pip pipe has a 3" flange that is MADE for a 3" exhaust
Here's an breakdown of the connections each forward slash (/) is a connection point and each number is the diameter of pipe on each side
tip(3")/(3")muffler(2.5")/(2.5")resonator(2.5")/(3")cat/Y-split/turbos/engine
This means the stock exhaust has a choke point of 2.5" AFTER the y pipe but the good news is the stock y pipe.
My guess is this was the "good enough" system ford decided to use for all the trucks to be the middle ground for all the engines while keeping NVH to a minimum.
Things we can know for certain:
1. you will never see a performance benefit from a resonator delete
2. a catback will always give benefits even if the software cuts maximum torque output as it is programmed to do.
I know this is common knowledge for many but I had to do some research to get it all and mic the pipes so here it is in one post.
Update:
