481 - 500 of 536 Posts
Discussion Starter #484
Right up until the nutsert wallows out and you have to open the tailgate to put a nut and lock washer on the back. Wah wah wah...
Which doesn't normally happen if you follow the instructions and use the blue lock tight. But....if you fear that....you can do the nut/washer thing on the front end.....it's just that your average Joe DIY guy isn't going to go to that much trouble. Hence the nutsert. But hey...whatever makes your socks roll up and down.
Kinda like buying a 3.5L f150 then spending x amount of dollars to get the oil out of your catch can? Anything can happen @ any time. Ie. A battery issue @ 46,000 kilometres.
Why always negative?
Why buy a platinum then downgrade it to raptor status haha
Sent from my white iPad 3 in a http://www.red.org/en/ smart case using an app called Tapatalk
I prefer the tap and die method with the blue lock tight. :)
Discussion Starter #491
Discussion Starter #493
Zero knowledge? Danica is a chic. She drives among guys. What else is there to know?
Discussion Starter #496
BOLT Lock Introduces Trailer Coupler Lock
For you guys with tag along trailers of any kind, not you can add a BOLT Lock to your couplers that may not be able to fit a traditional padlock.
BOLT Coupler Pin Lock Specifications ? BOLT Locks by Strattec
At SEMA 2014, they also introduced a Jeep hood lock, and are working on a fifth wheel lock.
The 5 guys at the bottom
Sent from my "unbent" iPhone 6 using Tapatalk
