I was wanting to add a power point to my truck located where the useless change holder is located. I popped out the change holder and there is a wiring harness connected to it. I was going to tap off this harness but upon checking for voltage there was no power to it. Does anyone know if there is a way to turn power on to this harness using Forscan. I’m not sure what this spot is used for in other trucks but this would be a lot easier than having to run wire to fuse panel.
If anyone can assist I would be grateful.
