1 - 18 of 18 Posts
I have never seen it done this way, but why can't you use the truck's weight to help install a new coilover? This is actually a 2011 Raptor, but the process on a regular f150 should be the same. Why not bolt the bottom shock on the LCA, bolt the rubber and steel insulator to the shock bucket, then slide the coil spring on, align it to the bottom coil saddle, and jack up the A-arm until the top shock bolt pokes through the insulator? Seems easier, safer, and (especially with the weight of that 6.2 iron block); the truck isn't going to move.
Automotive tire Motor vehicle Automotive design Bumper Automotive exterior
Discussion Starter · #3 · (Edited)
Automotive tire Vehicle Motor vehicle Bumper Automotive exterior
my other issue was that while it still hadn't pushed the thread far enough above the shock bucket to get the nut on, (but before I started lifting the front off the stands), I found out the floor jack was too short. My other larger one is too tall to get under the LCA, so there's that.. It can be done with a pair of those scary spring compressor clamps, (and you'd need to leave the three isolator nuts loose so you can safely wiggle the shock threads through it), but the experiment was to see if the shock & coil can be assembled On the truck; without spring compressors. Apparently it can be done, but not recommended.
· Moderstrator
You can do this and I have but only when I could chain the front end down. Sometimes, depending upon where the lift/jack mounts are placed the springs can lift the front end and you can't even get the threads all the way through to start the nut. Our shop jacks always had chain slots that you could attach the frame to the jack and then jack up.
· Moderstrator
Man, I'm slow. That's like two posts in five minutes that show a moment ago for me and the post immediately before mine but I'm in 2nd. :oops: Seeing your pic, if you would have chained the frame to the bottom of your jack you would have had no problem. I'd have used the two holes visible in the frame and wrapped the chain under the jacks frame.
Discussion Starter · #6 ·
I just stopped trying to overthink it, and did it opposite of the removal process. I kept the top insulator loose, hung the new Fox 2.5& Geiser coil (on the bottom perch), then wiggled the bottom of the shock on the LCA. It's got fresh bushings, ball joints, and SPC cam locks with welded cam gussets. I rattlecanned the axles and LCA's, swapped the UCA's for Blitzkrieg's, swapped the outer tie rods for the RPG billet aluminum/stainless heim versions.
Automotive tire Automotive design Motor vehicle Machine Space
· Moderstrator
@bentruby - I’ve seen that spring compressor on eBay and thought about getting one - what’s your review of it?
It works well, but you're getting what you pay for. No assembly or usage instructions are included. Take your time and make sure the strut is secure before disassembly. I was a bit nervous with it, but it was very stable as I struggled with seized nuts at the top of my OEM struts.
I used the smaller set of 'cups' on the struts on the F150.
Anyone use a spring compressor like this one? I have a set of Bilstein struts and shock to install and I was thinking of getting this one to use.
I used the one shaped like the pic below, highly questionable. The issue is the length of the struts, they're long and much stronger than a car's struts (the rods were definitely bending.
Font Machine Auto part Metal Art
I have never done this and all I can think of is... why not?
Could have bolt torque issues on the top hat? But perhaps not.
I mainly wanted to add... That is the most beautiful upper control arm I have ever seen!
I finally had to break down and buy a safe spring compressor, I’ve been doing side jobs here and there for family and friends and for whatever reason lately a bunch of coilovers/struts.
This thing is a beast.
Lol it’s actually at my buddy’s right now. It’s funny because I was joking with him and told him I was taking that picture so I remember what it looks like when I come to pick it up. I said you better not scratch it!
I lost count of how many times him and I were hiding behind a board trying to ratchet down those cheap scary sketchy ones.
1 - 18 of 18 Posts
