1 - 3 of 3 Posts
I have a 2013 F150 EB that I've modded quite a bit with mainly performance mods, and when I launch in 4WD the front end bounces like crazy (only 3-5 PSI launches). I put a 2" level kit on the front a while ago and since then it's been an issue. I'm thinking of putting limit straps on to combat this but unsure of if I should measure while on the ground or backing off an inch while the struts are extended, since I haven't found anyone that has used straps for launching. I measured from the control arms to a good place on the frame and it's 18" while on the ground. Thoughts?
What kind of leveling kit? Pucks or an actual lift shock?
If its a puck then you may be overextending the CV's during the launch. The pucks just push the shock down so they extend down 2" farther at full extension, and bottom out 2" earlier.
1 - 3 of 3 Posts
