So i have a XDI Evo and a DW400 in tank and have the truck tuned for E85. Truck has ran great for 6 months, absolutely no issues at around 48 lb/min air flow and E85. I noticed about a month or 2 ago (getting colder here in iowa) that my truck was mis firing at WOT and i watch fuel pressure and it was dropping to 1000-1200 psi at WOT. Very bad. I thought maybe i was hitting some higher boost numbers due to cold weather, and sure enough I seen 52lb min for a sec. So figured I just needed a tune that backs down the boost.. So I continue to drive the truck and just don't get on the throttle. Some weeks go by and I test it again and I see pressure start to tank at only 34 lb min air flow. Which is way less flow than my summer numbers. This leads me to believe I for sure have a fuel pressure issue.
I pulled the in tank pump tonight, and have some metal and dirt on the tank filter, and a little junk in the tank. (the tank/filter was absolutely clean when i changed this pump 6 months ago at 140k miles). So in the last 10k miles or so, debris has gotten into the tank. I'm not sure this is enough to cause any flow issues though.
Looking for any advice on where to go. Should i just buy a new in tank pump? Anything to look for on my HPFP? Its sounds good and normal. Do HPFP's wipe cams often?
