1 - 11 of 11 Posts
I have a 2011 3.5L which blew up and I transplanted the engine , BCM and ECM and cluster. The only real issue I am having is my miles or km to empty is always wrong. It always reads too much and drops off very fast. When I am on empty it reaches zero, but when I am full it reads about 1.5 X more than reality will be. I am assuming this is because the truck I took the parts from may have had a larger tank and its calculating things based on that. Is there a menu where I can fix that in, or is this a dealer / fancy scan tool repair?
It is my understanding that you can update this parameter via forscan.
in your case line 720-01-01 should be updated. Leave values in the x positions alone and only change 82 or 81 to match the tank.
xxxx xxxx 82xx for the 36 gallon tank.
xxxx xxxx 81xx for the 26 gallon tank.
Awesome, I will have to get that. I already have an old bluetooth ELM 327 OBD2 but it sounds like it won't work and I might have to get a new one.
If you are using a laptop, the USB version can be bought for $20 or less. Works for me and zero connection issues.
keep us updated
The software is free. You just need to register and request a 3 month trial licence to make changes to your truck. The adapter is around $20 to connect to a laptop pc, if you have one. You can request as many 3 month licenses as you need when they expire. No cost for the software. The ELM needs a switch for ms-can and hs-can.
ELM 327 USB
Discussion Starter #8
Finally received the OBD2 cable in the mail and sure enough reprogrammed to 26 gal tank, and distance remaining dropped down!! Thanks for your help!
Now you can do all kinds of other mods....
Discussion Starter #11
Ya next I plan to fix my airbag light, but thats proving to be a little harder.
1 - 11 of 11 Posts
