I am back working on my stereo installation and was looking at doing the Big 4 this weekend (in the 70's today and 80's tomorrow). My truck has the hall effect sensor around the two ground wires coming off the battery (looks like a 4 gauge and 8 gauge wires) so I have done a bit of searching with no real definitive answer.
I have a 1/0 wire running from the battery positive terminal to behind the back seat and into a fused distribution block of which will run (3) 8 gauge wires to the amps. From the amps I will run 8 gauge grounds to the body which is what prompted me to look at a chassis to body ground wire to compliment the additional current use of the amps. Typically I upgrade the alternator to battery, battery to chassis or engine block, engine block to chassis, and then either chassis to body or engine block to body to finish things up.
The hall effect sensor has me concerned in that I am thinking I need to run any additional or replacement ground wires from the battery to the chassis or engine block through this sensor as well so the BCM works correctly. This would mean that when it senses the additional pull from the amps it will ramp up the alternator. I looked at mine and I do not see a way that I can get another wire through there with the factory ones that is anything larger than 8 gauge and I might be able to grease up two 8 gauge lines and get them through there but I doubt it.
Does anyone now anything about the hall effect sensor in that a guy might be able to find one that has a larger opening and install that? I am open to ideas here but I really do not want to bypass it with a ground lead as I am concerned the BCM would not operate correctly.
