1 - 10 of 10 Posts
2013 F150 3.5l 4x4 FX4
Hello everyone, I am new here but I don’t know if this belongs in this thread so correct me if I need to adjust. I am having an issue with my driver side headlight high beam, it constantly stays on after I have used the high beams but I have noticed it sometimes turns off like goes back to low beam but not noticed what causes it to go into low beam. I have a 2013 fx4 3.5 4x4 f150 and would like to know that cause of this or some solutions to the issue. Please and thank you.
Are the housings reflective or projector? If it’s the projector type, the shutter shield gets stuck over time.
The HID projector headlights use a single filament HID that has a shield in front of it to produce a cut off for low beam. When high beam is wanted, the shield is fully removed.
If it’s the standard reflector housing, then you may have a wiring issue.
What @SrpRacing said. A 2013 FX4 should have HID’s with the smoked housing. This sounds very similar to an issue I had with my last truck, and a Ford tech friend of mine said the same thing about the shutters. Wouldn’t you know brought it to Ford and he was right on the money.
Discussion Starter · #6 ·
So Pretty much I’d have to replace the headlight housing to fix it?
Do they look like these?
I did the halogen to HID swap on my XLT. I used OEM housing and once I had a light stay on bright. Toggled high to low and never happened again. These housing are very expensive so I found used ones. Haven’t been all that impressed with the light pattern. You might be better off with aftermarket lights.
Wheel Tire Car Vehicle Automotive side marker light
I did a ton of research at the time and couldn’t come up with a fix I could do myself other than throwing aftermarket housings in. So the only fix I’m aware of is a new headlight unfortunately.
Discussion Starter · #9 ·
My headlight looks exactly like that so I might just look into a n aftermarket headlight set
Anything aftermarket will be a downgrade from the HIDs. They also use a specific connector compared to the standard H13.
Only improvement you can make to the HIDs is retrofitting them.
1 - 10 of 10 Posts
