High trans temp
37K views 33 replies 15 participants last post by  TOWMA8R
I sweat more when I'm working in my yard then when I'm just sitting on my porch... ;)
Towing is hard on a rig... It's 100* outside, you got the ac on and going up a grade... Sure, the temps are going to rise..
The good thing is you saw it happening and pulled over and didn't let it overheat..
My trans was running 195* going up some grades in the Sierras in California and it was 8* outside! Yes, I know the trans is thermostatically controlled...
But, towing puts more strain on any rig, so it's just gonna run hotter in some cases..
I've seen 225* on mine at times, but only for short time to get thru some switch back curves going up hill but I never did see the gauge actually move..
Dunno what the answer is, but I think you did the right thing and let it cool down when you saw the gauge move.. I've never seen a Ford temp gauge move above 'normal'....
Good luck!
Mitch
