Hey everyone, Ive got a question. My truck can tow around 11 thousand pounds. So I kept that in mind while i was buying my hitch set up. My ball mount, and pin are both rated for around 10000 lbs. And I bought a 2" ball, online, that was rated for the same. However, the shaft of the ball wont fit into the hole of the ball mount (shaft is 1 1/4" diameter). I went to the hardware store and all the balls with the 1"shaft are rated at 5000 lbs. Can those balls tow significantly more than that, or should I not go over 5000 lbs? Thanks for your advice!
