Check if your oil dip stick tube it holding it on. You may need to remove the dip stick tube first.
No I didn't. I cannot; there is only a plastic protrusion molded into the valve cover for my dipstick.Just to confirm, you removed the TUBE the dipstick goes into?
It has barely budged, though is opening from the bottom slightly more than from the top.Is it loose on the other end away from the solenoids?
Or has it not budged anywhere all the way around?
2 kinds of stuck, if you know what I mean?![]()
