Help …
I am at a loss here 2015 FX4, 126K miles, stock.
A couple of days ago in my commute home I heard some metal on metal scraping sounds while driving home. It sounded like I had lost my brakes pads in a split second and that the caliper was now digging into the brake rotor. By the time I got to the shoulder, no noise. I drove home the rest of the way, after checking a few things, no noise. It happened a day or two later, on a different section of road. Then it happened again …
I have checked the heat shields, I had rock/debris stuck there some excursions.
Yesterday i had to Reno (about 200 miles) And the noise came back a couple of time.
Transmission never got hot.
Front pads have 7 mm on them. Rear are brand new.
Noise sometimes changes when you turn the steering wheel, sometimes not.
The noise is rotational, and the truck must be moving for the noise to occur. So not engine related.
Brakes are solid.
Wheel bearings pass the shake test.
No leaks under the vehicle.
The noise is still there while the vehicle is in motion, but in neutral=.
The noise has occurred at 70mph and at 5mph
One thing to note, I put the truck in 4A yesterday while coming over Donner Pass, lots of ice and blowing snow. Since then, I have not heard the noise once. Not sure if that is a coincidence or something more relevant.
Any thoughts on what this noise can be?
Brakes are solid.
