1 - 7 of 7 Posts
*TRANSMISSION OIL COOLER*This was a very quick simple install, maybe 45 minutes start to finish. I was able to fill the cooler up with ULV Mercon ATF with a little funnel I made, even with the barbs facing down I was able to keep the cooler at about a 45° angle and turn down the hoses to connect before turning upright and connecting to the brackets. It holds a little less than 1/2qrt. Over here in the AZ summer's normal cruising will see 200-205° temps, we'll see if this keeps it more around the 190° since that's when the cooler comes into play anyways. M&M's
Very nice. I see you have their intercooler too.
Do you tow a lot?
Sent from my Pixel 2 XL using Tapatalk
Do you tow a lot?
I tow a wakeboard boat a lot, around 6k. The mishimoto stuff is top notch high quality stuff. Perfect fits on both items.
I've got a CVFab intercooler. I'm sure the Mishimoto is just as good. Ford really walks the line with it's cooling....
I like this. I want one.
1 - 7 of 7 Posts
