I just installed a new tune on my truck and I'm getting positive knock counts on light throttle when accelerating from a stop and light throttle acceleration going up hill. Usually under 3 but I get spikes occasionally that have gone as high as 9.5.
Oh that's high....I just installed a new tune on my truck and I'm getting positive knock counts on light throttle when accelerating from a stop and light throttle acceleration going up hill. Usually under 3 but I get spikes occasionally that have gone as high as 9.5.
It's MPT 93 performanceWhat tune are running....I've never seen 9.5*.
You sure you aren't looking at timing? (just asking to make sure).
Would the Livewire to multiple logs or do I have to download each one?Oh that's high....
Log it and send off for a revision.
This is just at part throttle. No WOTYou will get short spikes sometimes after letting completely off after a WOT run, but I've never seen one go above 5 even with the stock or canned tunes.
Probably be better to use a lap top to log...Would the Livewire to multiple logs or do I have to download each one?
Also it's an occasional spike so it won't happen all the time.
I see this same thing. I just discovered it when I started watching kr in real time through the TS. Only does it at light throttle and the kr holds and does not drop. Heavier throttle and more boost and KR looks really good...even in 6th gear under load it is way in the negatives.I just installed a new tune on my truck and I'm getting positive knock counts on light throttle when accelerating from a stop and light throttle acceleration going up hill. Usually under 3 but I get spikes occasionally that have gone as high as 9.5.
Just repeating what those in the know have said..constant knock, even 2-3, isn't good. The ECM should pull or add timing quickly so the knock should drop and not stay constant. Mine stays between -5 and 0 at WOT.Is knock normal on WOT pulls? Between 2-3.. Ideal should be zero correct? I just want to make sure I'm not pushing the truck too hard that I may damage the engine
What tune are you running?Just repeating what those in the know have said..constant knock, even 2-3, isn't good. The ECM should pull or add timing quickly so the knock should drop and not stay constant. Mine stays between -5 and 0 at WOT.
