1 - 12 of 12 Posts
I have been doing a tone of research and have found not a lot of information to confirm this. I called a few tuners and asked this question as well, I get a run around answer, but nothing concrete.... Only one tuner has said over the phone that, not so much but its a good idea to be properly gaped. I kinda read between the lines on that one, but not sure.... So I would like to know. I have posted this before (below) from MPT site: (they seem to be the only ones to confirm it)
STOP AND READ THIS BEFORE SELECTING YOUR TUNES
What should I set my spark plug gap at?
Unlike previous years we haven't yet found a need to re-gap the stock 2017 - 2019 Ecoboost spark plugs.
Thoughts, knowledge and/or experiences - Confirm, deny or debate?
Interesting I have been wondering the same. I also have been unable to find any excerpts stating it’s a necessity where in the gen 1 they sure as hell let you know it.
Old school from the muscle car years, and ran a few HP high compression vehicles that ate plugs, my 68 Z28 went thru them every 7-8000 miles. When I used it at the dragstrip with J8 Champions I got the best performance but they would be gone in a few hundred miles. I always gaped new plugs, never gaped used plugs. That 302 was fussy about gaps. Found re-gaping used heat-cycled plugs would go back to the worn gaps quickly, figured they annealed and returned after startup.
As a result I always check gaps on new plugs before installation, understanding the advacements in ingnition over the last 30-40 years, simple and easy to do. It's also a simple tuning step and made a differance in the idle on my tuned 2.7, running NGK 6510 gaped at .026 instead of .028. KM
When you really start to get turned up you need to switch to a sp542 or ngk ILTR7N8 (95822) gapped at .028.
For mild tunes you'll be fine on stock stuff.
Sent from my SM-N975U using Tapatalk
Understood, as a street and mild trail vehicle, I'll stay with the longer lived dual precious metal plugs . KM
I called MPT (since I posted there quote) and a well known tuner I have used on the site...... I was told by MPT absolutely no need to for any HP level on the 17's and up..
The other tuner (nameless) said its just a good idea to be properly gaped.... they would not confirm if this is accurate.
So twist it, I had my buddy call the same tuner, tell him he had a 15, wants tunes and what does he need to do.... get the tune and buy the plugs pre-gaped to .28 ish
Twist again, had another buddy call, says he has a 18 and wants a tune...... ask about plugs and was told, just make sure they are gaped properly but its not necessary to buy there plugs pre gaped .... WTH
So I called another tuner, not so popular....... blown up a few things (hint hint) he advised me on the new trucks the plugs are gaped closer and he has not seen a need to run any other plug other than the stock plugs but an older eco its a must to gap and get a better plug than OEM.... So he is a tuner, his reputation is questionable but he confirms what MPT stated...
You'll definitely hear different things from tuners or engine builders. My personal experience, with water meth injection pulling -20 to -25 on fuel, I was blowing spark out at factory gap. I'm down to .025 on a set of colder plugs, no issues, no blow out.
Discussion Starter #9
I can understand with the meth, I used to run meth in my other vehicles..... but for octane fuel and a tune, is there a need for the newer eco's....
Called another tuner today, one with not so great of a reputation here or any other forum..... he says not on the newer eco's.....
Wish I could get a straight answer from a reputable tuner
Discussion Starter #10
Not sure the reason for no legs for this post but I had a pretty extensive talk with a well known tuner..... It appears to be accurate
I am not running very high boost on my own truck, it's mostly timing to make the power. I have found no breakup or spark blowout issues at a stock gap of 032 (even at 500+ whp and 550+ wtq). It just isn't a problem on this new ignition system at 18-21 psi of boost. Maybe at 23 lbs of boost you may run into some blowout where you need to gap down to 028.
Discussion Starter #12
Appreciate the feed back Sir!
1 - 12 of 12 Posts
