1 - 10 of 10 Posts
2022 F150 SCREW, Power Boost, 6.5' Box, 4x4, 1645# CC
I have a couple of pictures. Just wondering if they are the lithium battery and the heat exchanger, respectively.
Lithium Battery (2 pics)?
Tire Wheel Automotive lighting Automotive tire Hood
Gas Auto part Automotive exterior Household hardware Motor vehicle
Heat Exchanger?
Automotive tire Car Automotive design Motor vehicle Bumper
That is the exhaust heat exchanger.
I don't know if that's the battery since I can't see it's orientation. But I didn't think it was on its edge and running front to rear parallel to the exhaust, but rather laying flat side to side just under the rear of the cab.
Vehicle Motor vehicle Tire Wheel Automotive tire
Reactions: Atlee
Discussion Starter · #3 ·
I think that silver/aluminum colored box next to the starboard side chassis rail in your picture is, I believe, what I took a picture of. I didn't see what is above the battery and the gas tank and muffler.
I do wonder what that silver/aluminum colored box is. It has, what I presume, is a symbol for high voltage.
It is one of 3 voltage converters in the truck. Due to its location, I suspect it's the high voltage converter. The other 2 are under the hood. I'll see if I can dig up the voltage loop diagram.
Edit: looks like that's the inverter for the Alternating current onboard
Organism Line Slope Font Terrestrial plant
Discussion Starter · #5 ·
Thanks for the info. I did notice a sticker on that High voltage inverter which read, "If dropped, discard".
Reactions: snakebitten
I saw that sticker too. Interesting.
Discussion Starter · #7 ·
Figuring that piece isn't cheap, the folks handling it better not have butter fingers.
However, a butterfinger candy bar wouldn't be bad right now. :)
A few more images of the component layout
Automotive parking light Product Motor vehicle Automotive tail & brake light Automotive lighting
Automotive parking light Tire Hood Wheel Automotive lighting
Light Product Output device Line Font
Reactions: Atlee
Discussion Starter · #9 ·
1 - 10 of 10 Posts
