Braggard.
(I'm envious)
(I'm envious)
Don't be. I'm a boring ol goat. Just ask Ms Beautiful.Braggard.
(I'm envious)
I won’t have the fancy slide outs and copious space the run of the mil haulers have but ill sure appreciate the design ive put into our square box that allows me the flexibility to do whatever we wantAlright, so I have to put a relay on the power converter 120V hot wire. The problem is all my non-GFCI outlets are tied into the same breaker as the converter and so I can't just cut power to the breaker, I have to catch the connection on the power converter feed after the breaker. I will just trigger the relay off the shore 120V hot wire so that its only on when the shore power is plugged in.
The only other option was to disconnect the battery from the distribution panel, but this seems highly inefficient as I would be converting 12V DC from the battery to 120V AC with the inverter, which would then feed that 120V to the power converter which would turn it back to 12V DC to continue to power the lights and refrigerator and stuff. That seems silly.
I think the problem might be that I have a switch on the gen to run 120V only, or 120V and 240V. The 240V plug and adapter won't power the trailer if I have it flipped to 120V only mode. So its either turning off one(the wrong one), or both hot wires on the 240V plug when in that mode. I gotta break out my voltmeter and see what its doing.They usually are. I wonder if it's just one 120v bank that's throwing?
With those adapters you don't get to choose which bank you are plugging into.
Are there separate 20A receptacles for each bank? You could try the AC on the other?
Correct. I am using one of these to convert to my 30A 120V rv connection:From what I understand the 240v 30A outlet on the truck is the standard NEMA L14 that's on other generators. Is yours the same?
Bonus, lol.![]()
Well the bikes didnt tear the bumper off including about 20 miles of dirt roads.
So after you get all this sorted out, you should design an "add-on" extended battery pack for the Powerboost. Even if just ONE of those could be hacked into the battery management system.Thats 6528 Wh worth of battery, or 4.4x a F150 Powerboost battery![]()
