1 - 3 of 3 Posts
We have a a Boost max Tuner by JMS here for sale. It regularly sells for $399 but we are offering it for $389, below is some info on the Boost Max!
BoostMAX • Add 90+rwhp to your 3.5L EcoBoost in minutes • Works on all 3.5L EcoBoost Vehicles • Plug and Play Installation • Stackable with JMS Calibrations
Plug and Play • Works on all 3.5L EcoBoost Vehicles • Installs in minutes
Increase Horsepower • Reduce Turbo Lag and Improve Vehicle Acceleration.
Enhance low, mid and high-range horsepower and torque • Add up to 5psi of extra boost.
Remote Boost Adjustment Knob Included • Dial in your exact boost enhancement setting.
Can also be stacked with a JMS Custom Tune File delivered to the ECU via a SCT handheld.
Or stack with JMS PedalMAX (PX-5000-1114F) to maximize low and mid-range performance.
  • Simple Plug & Play Installation
  • Installs in just minutes
  • Unplug your stock MAP, TIP and Pedal connector and connect JMS BoostMAX.
  • Improves vehicle acceleration.
  • Increases low and mid-range horsepower and torque.
  • Add up to 5psi via Remote Boost Adjustment Knob.
  • Works on all 3.5L Ford Ecoboost Vehicles
  • Warranty Friendly
  • Easy Plug & Play Installation
  • Increases fuel economy with normal use
  • Reduce Turbo Lag
  • Ecoboost Vehicles can have noticable Turbo Lag, this product helps reduce the problem.
  • Customers report 2+mpg when driven normally
  • Stack with PedalMAX to further improve acceleration.
  • PedalMAX also eliminates turbo lag and helps solve stalling when taking off from a stop in a manual transmission vehicle.
  • Green Status LED: Know at a glance what the unit is doing.
  • Solid Green = powered on
  • Red LED's blink to provide diagnoistic information
  • Performance Dyno Sheets listed in instructions
  • Use the included Remote Boost Control Knob to fine tune your throttle enhancement setting.
  • Or plug in the 87 octane red chip to optimize 87 octane performance.
  • Designed to be stacked with an SCT Handheld and a JMS Custom Tune File for the ultimate performance.
  • Adjust power and performance on the fly with the Remote Boost Control Knob.
  • Stackable with PedalMAX • PX-5000-1114F
Each BoostMAX Kit Contains: BoostMAX Boost Enhancer, Plug & Play Wiring Harness, Remote Boost Control Knob, Installation Kit, Set of Instructions
1 - 3 of 3 Posts
