I've never even tried my keypad in 5+ years of owning this truck! I don't even know what the code is with my brain anyway! (I have it in my wallet) You must use it all the time to get that kind of wear on those 4 keys..
I shared my idea with a couple friends who didn't think of it. I will let you all in on my idea to have my truck number on me. I have it stored in my cell phone as a chosen (think of a name to call your truck) persons phone number. Most people have their cell phone on them these days. Also I believe that Ford still puts the door code on the inside of your fuse box cover. Just in case you forgot it or purchased the truck used and didn't get that info.
Hello I have a 2017 lariat 3.5 that I recently have managed to blow holes on both sides of the motor do to a bad tune lol and sence ive come across a 2018 navigator 3.5 EB is it compatible
Hello all. I have a 2011 with a blown up engine. What I did was buy an entire 2014 parts truck. Am I ok to just swap in the engine only? Do I need to use 2014 wire harness? 2014 computer? Anything else?
Also I am thinking about swapping in the entire interior because the 2014 is a Lariat...
Hi guys, new owner here and I'm just wondering if this function can be disabled...seems like such a waste of power, and potential long term wear.
Thanks for your time!
Sadz.
Anyone hooked up an aftermarket sub/amp in a 2019 XLT supercrew yet? I just traded in my 2017 XLT supercrew and there was a plug in harness back up against the rear of the cab on the drivers side to plug into to get the remote signal and speaker signal. I just got all the factory speakers...
I set the Cruise Control for my desired speed. Works fine. But when I brake it cuts out. I checked the owner's manual and I'm doing it correctly. It's a Type 1 version.
Very annoying as I have to reset it every time after braking.
(Tried to do a search within this section but couldn't find a...
