81 - 100 of 126 Posts
Are those GT turbos heavier than the stockers?
Discussion Starter #83
It looks like its the driver side manifold, same place a Broell, the long gap between the studs:
Red arrow is what i think is carbon, green arrow is the gasket, blue arrow points towards the rear.
I couldn’t get a good angle on this side, but i checked the entire passenger side manifold and saw nothing, and the rest of the drivers side manifold looked fine.
All studs are still there.
Hopefully it’s not the actual issue. But if it is, personally I would pull them, have them machines flat and re-install with SS ARP or Ford Studs.
@Blown F-150 if you recall when I got my CRP Manifolds, that I thought my manifolds were not totally flat at the flange (when I checked with a straight edge) when I bought them a year or two ago?
I took them to a machine shop, that confirmed they weren't perfectly straight, and milled them flat.
Reactions: Blown F-150
Discussion Starter #87
My motivation to dive into this is extremely low. I have the truck up on jack stands and front tires off, but I cannot decide if I wanna just take the whole thing apart and see if I have a bad gasket or manifold, or try to retighten the studs again.
Problem is, retightening with the turbo on is impossible with a torque wrench. Some of the studs are incredible hard to get to. If I take the turbo off then I am 95% the way there anyways and could just pull the manifold at the point.
Discussion Starter #89
TQ WRENCH? Crank them down. You don't need a tq wrench on those and I follow specs!
Right, I didnt use one last time. CRP suggested I retorque to spec, but I think I am past that at this point between corrosion and my previous torquing.
Reactions: SrpRacing
Thats the thing, they are not new fasteners anymore, cranking them to spec pretty much means they will be under torqued.
Discussion Starter #92
Alright, well, i dove in. Tightened studs 1-5 per the manual before the kiddo got home and called it for the night.
Discussion Starter #94 (Edited)
Did they seem fairly easy to turn?
No, I got MAYBE an 8th of a turn before I couldn't realistically move them with my 1/4" drive. But I still have to do the bottom rear, and rear most ones. Bottom rear one is a major pain as its right behind the turbo and last time I could only get a normal wrench on it. My crows foot kept slipping off and my 1/4" drive with my cut down socket was to big to fit
Yeah, that's not a great sign. I'm guessing that something is warped or that gasket is not sealing anymore. Yes, I'm stating the obvious, lol.
Discussion Starter #96
How much of a pain is it to pull the oil return off the block? Is it just a slip fit like it was in my Jeep turbo?
This would give me a better angle on the one hidden bolt
How much of a PITA is it to pull the oil return off the block? Is it just a slip fit like it was in my Jeep turbo?
Yeah, it's just a pipe and O-ring on the Block side. I'm not sure if you could get it out with the turbo there though.
Discussion Starter #98
All the bolts are pretty dang tight. I did two passes in the pattern from the manual and am not holding my breath.
Reactions: WooBoost
Discussion Starter #100
It seems to be sealed again. I cold started it and immediately started driving. I jumped on it pulling onto the main road which is only about 100 yards from the driveway and no noise. Tried a bunch of pulls in manual mode in various gears and didn’t hear anything.
I guess well see how long it can go this time.
