Bump?!I see that they come in the lift kits. Can you get them separate???
i have the 1" block in the rear. Rear sits .5" higher. Measuring from the ground to top of wheel wheel archI don't know the answer to your question, but Fabtech Motorsports probably can. Question for you...did you have to put that 1" rear block kit in to get your truck back level once you installed the RC 2.5" front kit or does it sit slightly higher in the rear?
