Looking to do a simple 2" drop in the rear with some adjustable shackles to level the vehicle out. I hadn't put any thought into what shocks i'll need to support the lowered ride height. I really wanted Bilsteins 5100's but I guess they won't cut it due to they'll be mid-compressed at 2''.
Has anyone done a shackle drop and replaced your shocks as well? What set did you go with and how to do you like it? Any recommendations in general are beneficial.
I will have to look but i dont think the tremor 4wd has the block. I installed 2 inch drop shackles and truck sits level. I also want to go to bilstein 5100 on all 4 corners.
I have 2 inch shackle on mine level it. Next year I plan to do bilstein all around except I will be using 2wd sets. I have talked to member on here and Stage 3...according to them the 2wd front strut is 1 inch shorter than 4x4, otherwise the same. Then i will pull block in rear and potentially cut it in half to keep the rear slightly above front.
If you only want to level, just pull the block on 4x4, although the shackle is pretty easy to install.
I just want to make sure I'm in the right area here before I make this purchase. From what I've read thus far, I can get away with a 2" shackle drop, stock height up front, on a 2wd Tremor, and still be able to put these on without issue...
Ended up ordering front ones from stage 3 and rear ones from 4wd parts, i had a gift certificate . Rear ones are for a 2wd since i have lowering shackles installed. Hope to get them on in next few weeks.
Front ones showed up Saturday , very well built . Rear ones are supposed to show up monday. I actually had some bilstein 5100 temporarily on rear of my Raptor for a week while my Fox shocks were getting rebuilt. They really did a decent job.
Got the Bilsteins installed this weekend , Rides really nice not so bouncy in rear anymore. Could really tell the difference on way to work this morning , my normal route . Steering response seems tad better , truck tracks good with slight steering wheel movements feels like it is on rails. No wheel hop either on a hard 2 wheel launch just tire spin.
Hey MyfirstF150, what set-up did you end up going with? Just bought a Tremor and I want to lower the rear end and replace the shocks. Thanks in advance!
