21 - 40 of 52 Posts
Pass side rear is hard. Have to unclip from side of trans and pull it down to get to, other 3 are simple. Front drivers side you'll get under the hood. A 15mm deep wall, swivel and 18" extension will get all 4 turbo nuts with ease.
Thanks. Now To convince the wife dp's will increase MPG :D
Just an FYI....
After about 1,000 miles I started smelling the exhaust leak. Turns out my left side had become slightly loose. Tightened it back up and good as new! Thanks again MAK - great product.
I have a 2012 EB with the Off-road down-pipes. When I first installed, everything was fine after a little re-tightening, but now my truck is starting to throw the CEL code for bad catalytic connverters. I have a SCT tuner, but cannot find out how to turn that CEL off. Is it written into a custom tune, or do I have to keep clearing DTC codes to turn that stupid Check engine light off for not having cats? Thanks!
Supporting Vendor
Discussion Starter #32
You need to get with your custom tuner and have him write you a custom tune for your combination. That will take care of the light.
21 - 40 of 52 Posts
