I have been trying to find black center caps for my 2018's 20" OEM Special Edition black toned wheels. I always thought black center caps would look better than the OEM blue center caps. And now that I've replaced the "chrome" lug nits with black, I am even more interested in replacing the center caps.
The problem is - I cannot find any center caps that are of the 3" / 74 mm size that will actually pop into the center area securely. The black ones I have found (CL3Z-1130-B) are the right size on the external surface, but the inside tabs to clip into the wheel are all too small in diameter to be secure.
So - I bought a set of 4 sacrificial blue center caps FL34-1A096-BA off eBay and managed to get the first one from blue to black! Basically, I peeled of the blue cap from the mounting base, cut the black cap's mounting tabs off and glued the black cap top onto the blue cap's base.
I will document the step-by-step for the next center cap I convert.
For now, Prototype #1 is below.
Front wheel with black lug nuts and blue center cap - they gotta be black!
Black center cap with mounting tabs too narrow to be secure.
Pre-owned blue center cap that fits my wheels, from which I peeled off the blue metal top layer.
OEM Blue cap's back on top, new black cap's back on bottom.
Note how old cap's tabs are spaced further out, the new black cap's tabs are inset a bit.
Finished prototype - black cap glued to blue cap's base.
