621 - 640 of 1,141 Posts
I'm looking to have Ford do the horse power tune on my 22 3.5 . Is it worth it. 450 horse is great, but what happens to torque. Does it stay at 500ftp or go up. Thanks
Bro just get unleashed and follow Torries tuning guide. If you're worried about longevity, Torrie can leave a little in the tank so you're never stressing it.
You won't be happy with Fords Tune IMO
Also going to figure out a way to bring the exhaust out the side with two pipes. I think I have a plan, I’ll post when I do it.
After I do that, I’ll be getting a meth kit also.
I've finally dialed in my exhaust after about a year, I'll get pictures but I love it. Completely custom from the downpipes back, equal length, into a H-Pipe, then dual Black Widow Widowmakers, and dual 4" tips exited right before rear tire
Discussion starter · #626 ·
Sweet. Definitely need some pics of that.
Discussion starter · #627 ·
I’d go with ZFG racing personally as they tune my truck. But Unleashed, or MPT and some others are really good.
Discussion starter · #628 ·
Ordered the meth kit from Nitrous Express and I did happen to see that they have a nitrous kit for the 3.5 Ecoboost…. Hmmmmm
Have you played with N2O before? I've run it quite a bit over the years on both street cars and sand dragsters. Never anything with both Meth and Nitrous. Unless someone makes a high-end kit dedicated to the 3.5, I'd take pause, and do a ton of research before I ran it on these twin spinner little peanut engines.
Discussion starter · #630 ·
Have you played with N2O before? I've run it quite a bit over the years on both street cars and sand dragsters. Never anything with both Meth and Nitrous. Unless someone makes a high-end kit dedicated to the 3.5, I'd take pause, and do a ton of research before I ran it on these twin spinner peanuts.
Oh I wouldn’t run both. And I probably won’t do nitrous, if I did, I’d ditch the meth kit. But, Jason Myers is at Livernois motorsports right now getting his truck tuned with stage 5 turbos and a fuel pump. It’s a 2021 powerboost. He has the nitrous kit on it and has had it on there for a little while now, it made 640hp and 700 something torque on that setup with stock turbos and I think a 50 shot. He texted me the other day and said Livernois just did his new dyno pulls and the hp number started with a 7. So he is really pushing it… and I’m really curious to see how it goes. (He ran nitrous on the stock tune and it was fine with it)
Discussion starter · #631 ·
So… I think my truck has a leveling kit spacer on the front. This picture is the truck sitting on flat ground
here’s a pic of my old 2.7 truck. You can see it’s much different. I don’t like how high my trucks front end is off the ground, so I want to remove the spacer if there is one. Does anyone know if 33” tires can work on a 2022, totally stock front end?
Discussion starter · #634 ·
Some quick research of the part number on the sticker says that's not a spacer.
I know the part number isn’t, that’s part of the strut. The spacer is on top of the strut I think
Discussion starter · #635 ·
There sure isn't as much real estate on those top studs. Something is different.
That’s what I’m sayin… something ain’t right. I’m gonna pull them off in a little bit and find out.
drop it like its hot! drop it like its hot!!!
Reactions: boostkingMatt
Discussion starter · #639 ·
Well, what do ya know!!! Looks like a 2” or 1.5” leveling spacer. Does anyone know what brand these are? Is this the rough country spacer?
