681 - 700 of 1,149 Posts
ML3Z-17906-LAPTM
The only thing different is the bumperette's.
owns 2017 Ford F-150 Lariat
Discussion starter · #682 ·
ML3Z-17906-LAPTM
Where does the exhaust hang from though? You know like the exhaust tips and pipes they have hangers on them, and look like they hang on some part of the bumper
I would go find a Tremor and climb under it.
Reactions: boostkingMatt
Discussion starter · #685 ·
These are the exit pipes for the 2021-2024 BAP appearance package that includes the dual exhaust.
I don't know if the hangars explain what you would see under the truck?
Discussion starter · #687 ·
Thanks for posting that. Yeah that’s helpful but I’ve kinda seen that already and gathered that both raptor and BAP and Tremor use the same exhaust hanger brackets for the tips. Then there’s only one other hanger I have to find.
Discussion starter · #688 ·
What I’m also trying to figure out is if I can use 17-20 raptor tailpipes and have them fit in the notched bumper. I think it will work. I know 21+ raptor tailpipes won’t work as well because the hangers are in different spots than would be needed on the f150 because the suspension is different.
Reactions: TOWMA8R
There is always a way, right!
May have missed somthing, is the twin under/in bumper what you want or would you settle on twin over axle to behind the back tire exhaust? Far as hangers for the bumper exit does not the Limited 3.5 HO use the Raptor exhaust? KM
owns 2017 Ford F150 XL
Discussion starter · #691 ·
I would take that yes but there’s no way to do that, and honestly I like the bumper exit, it appeals to me more.
Yes the limited uses the raptor exhaust except 2021+ the raptor tailpipes are different because the suspension design is different. So, I actually think that some 17-20 raptor tailpipes will fit on my setup.
Discussion starter · #692 ·
So. Today I ordered 17-20 Borla Raptor tailpipes.
Also figured out my truck has the mounting holes for all the exhaust hangers needed for a dual. So I ordered the tip hanger brackets, and one more frame hanger for the driver side tailpipe.
Then, I also ordered oem bumper end caps with the exhaust cutouts. I’ll have them painted Rapid red
Then, I ended up installing my whole methanol kit and whew, what a chore. I’m really happy with how the electrical came out. I ran everything in braided protective cover, and heat shrunk all connections. Stole the 12v switched source off the kick panel on passenger side, (I used a fuse tap, and came off a 10 amp space in there, and put a 20Amp fuse above it and the 10 amp one below, I think that will work and shouldn’t blow anything up, since I made sure power came in the side that the power flows. If you don’t, than it can blow the fuse below it from what I understand.)
I took the controller and turned the system off for now since I didn’t have time to prime it and all. It’s so nice to be able to run the setup and you don’t even have to have it turned on. I can literally turn off the spraying ability.
also I can set it to start spraying at whatever boost I want and tell it to be spraying 100% by a certain boost also. For now I chose to start spraying at 12 psi, and be 100% by 20 psi.
Reactions: Kinguni
Is ZFG tuning for the spray? KM
Discussion starter · #695 ·
I was at a jobsite today and saw a 2021+ tremor sitting there so I poked my head underneath and snapped a few photos as inconspicuously as I could. You can see that bracket for the tip mounts to the holes that are in my bumper bracket. I ordered two of those brackets, one for each side.
Then this was the only other hanger I wasn’t sure about and you can see, it mounts right where I thought (and my truck has holes for it)
Dude I'd try some Black Widow Widowmaker 10" or a DIDO Race Venom muffler on your truck. I have the 6" neighborhaters but they're a little loud on the highway. The widowmakers quiet it down a bit and you should get the full turbo whistle as it's not Perforated. Summit or Amazon will let you return it if you don't like it.
You could just dump it if you're happy
Discussion starter · #697 ·
I love the SPD exhaust, not turning back on that. Just need it to be dual out the back.
Discussion starter · #698 ·
This bad boy showed up today. Spelab Auto Parts rear differential cover. It’s got a little level ball with a window you can see in, and a fill plug on top, and comes with a gasket too. Not to mention how stout it is! It’s a thick boy!
Matt, I think I'm considering giving this a go at some point. The Valvetronic mufflers may be able to give the best of both worlds when desired..
Link to off forum removed
Unfortunately the problem with these ecoboost Engines is you have to pick either 2/3 out of great low rumble, mid rpm pickup, and WOT.
My true duals, H pipe, and dual 6" Widowmakers sound great at low rpms, crap at mid rpms, and good gnarly at WOT. The turbo whistle is great that's why I want a straight though non-perforated muffler, Perforated mufflers take whistle away
Unfortunately I tried the 10" widowmakers and they improve the mid rpm sound but take away quite a bit of the low rpm grunt. Can't win with these engines.
This bad boy showed up today. Spelab Auto Parts rear differential cover. It’s got a little level ball with a window you can see in, and a fill plug on top, and comes with a gasket too. Not to mention how stout it is! It’s a thick boy! View attachment 202277
Reminds me of my spicer cover. That will be a nice upgrade.
