1,121 - 1,139 of 1,139 Posts
Discussion starter · #1,121 ·
I got a 2017-2020 raptor fuel pump, the whole bucket assembly, and I dropped it in the tank. It’s for a 36 gallon and I had a 23 gallon just like you have. The fuel gauge on my dash showed slightly less than full when it was totally full. I didn’t feel like it was that big of an issue.
Reactions: JasonMink
Discussion starter · #1,123 ·
Yes 36gal.
I went from Winnfield La to Atlanta Ga. On one tank. 75mph the whole way, cruise control.
Then a raptor pump would be perfect and wouldn’t mess up your fuel gauge.
Discussion starter · #1,124 ·
Have you guys have ever wondered why the 2.7 and 3.5 Ecoboost turbos sound so different?
Even the Gen 1 3.5 which has turbos that are barely larger than the Gen 1 2.7 turbos still makes more compressor wheel sounds.
If you guys didn’t notice, the 2.7 turbos are standard rotation turbos meaning each turbo spins the same direction.
If you’re facing the front of the truck, each turbo spins to the right. This is easily figured out by looking at a picture of the turbine housings coming off the cylinder head.
The passenger side turbo sits up a little higher which is why it’s really visible from the engine bay.
The 3.5 is a mirror image setup. Both turbos spin the opposite directions.
Couple reasons why ford did this is probably because the 3.5 has exhaust manifolds, which uses up more space on the side of the engine. Having standard rotation turbos would not allow enough room for the turbos, hence ford did mirror to be able to pack them tighter, underneath the manifolds.
As you can see from the exhaust housings, the turbines spin the opposite direction.
This difference in spinning rotation probably causes the sound difference. Same direction rotation is probably quieter due to the difference of air swirling. But intake piping and tubing contributes as well. But my guess is that opposite rotation is louder in a shared y pipe intake system.
owns 2017 Ford F-150 Lariat
LOL I can’t wait to see it.
They’re always coming out with new stuff nobody else is doing.
Saw just today that they have Borg Warners for the Gen1 that flow like the Garret Powermax’s (+20% vs oem).
My encounters with them are just them doing an amazing job taking care of customers. It’s why if I need something I check to see if they sell it first.
Saw that too and thought they were the same as the Ford Racing set that were available already. The price is basicly the same. Either way pretty cool.
Discussion starter · #1,129 ·
I think they are better than the “GT” turbos.
Christmas in August! KM
Hey guys,I posted some of my races on my YouTube!!
Discussion starter · #1,133 ·
I’m very surprised how clean the oil is on my 3.5 when I change it.
This is 3000 miles. The oil is a dark gold color.
On my old 2.7 Ecoboost the oil was black as night at each 3000 mile oil change interval.
About time Matt! You may have been busy with life and such but it's good to hear from you again. Those are interesting swirly things you have there! KM
Discussion starter · #1,139 ·
Haha well I’m still here, just busy.
yes they are going to be awesome. The only 5 blade 46/56mm set! Can’t wait to get them.
