Yes.Without installing a boost gauge, how can I see how much the boost reads. Will my sct tuner log that?
I'm using a Scangauge2 and it works just fine.Id recommend a scangauge.
I think I will go this route just because I like gadgets to look at while traveling. I already have an old Android bluetooth capable phone gathering dust.Yes.
You can use the live link software and data log it.
Or get an obd dongle with Bluetooth and hook it up to an android device and rung the torque pro app...
If the truck isn't utilizing accurate sensors, the whole world crumbles.I use a Bluetooth Dongle and Torque Pro for Android. I have a old but still working original Galaxy Note that I put in my cradle on my dash. This only reads at the MAP sensor however. Only a gauge will read 100% accurate IMO.
My point is that "T-ing" into a vac line is going to read actual boost vs. what the ECU is commanding.If the truck isn't utilizing accurate sensors, the whole world crumbles.
At that point, what good is a standalone boost gauge?
Won't reading the intake vacuum from the ECU give me the actual boost?My point is that "T-ing" into a vac line is going to read actual boost vs. what the ECU is commanding.
This is live data, not commanded... View attachment 7819My point is that "T-ing" into a vac line is going to read actual boost vs. what the ECU is commanding.
Do you have a gauge though? Without one, I don't think there is any way to verify that this actually an accurate # (IMO.) I'm not doubting you, just going off what I've been told.This is live data, not commanded... View attachment 7819
You're right, there is no way to verify, without a mechanical gauge.Do you have a gauge though? Without one, I don't think there is any way to verify that this actually an accurate # (IMO.) I'm not doubting you, just going off what I've been told.
Either you are misunderstanding what you were told or you were told a lie... MAP sensors read manifold pressure (Manifold Absolute Pressure) and do it very accurately. The MAP sensor in our trucks does not "command" anything, it relays the total manifold pressure to the ECU so that the ECU can determine; along with data from the MAF sensor, Oxygen sensors and a host of other contributing sensors, what the ignition and fuel systems need to do in order to maintain optimal air/fuel ratios.Do you have a gauge though? Without one, I don't think there is any way to verify that this actually an accurate # (IMO.) I'm not doubting you, just going off what I've been told.
I thought I heard something about the one in the intake plenum being a 3 bar sensor...Either you are misunderstanding what you were told or you were told a lie... MAP sensors read manifold pressure (Manifold Absolute Pressure) and do it very accurately. The MAP sensor in our trucks does not "command" anything, it relays the total manifold pressure to the ECU so that the ECU can determine; along with data from the MAF sensor, Oxygen sensors and a host of other contributing sensors, what the ignition and fuel systems need to do in order to maintain optimal air/fuel ratios.
As stated above, the MAP sensor is every bit as accurate as a manual gauge. The only draw back to a MAP sensor is when you eclipse it's monitoring voltage maximum, it will stop relaying boost increases. So if you have a 1.5 BAR MAP sensor, it will reach it's voltage max and stop showing boost increases at 22 PSI. If you eclipse 22 PSI, you'll never know it because the MAP sensor will be "pegged."
I'm not certain where the factory MAP sensors in our trucks peg, but I'd venture to say that they are at least 1.5 BAR sensors since a 1 BAR would be pegged a 14.5 psi, not far above the factory boost peaks.
