1 - 6 of 6 Posts
Discount Tire Direct has the new Trail Series MR701 available!
F-150 Fitments
17x8.5 ET0 6-135 | Matte Black - $194.00 each | IN STOCK
17x8.5 ET0 6-135 | Matte Bronze - $194.00 each | ON ORDER
Due to website programming delays, the MR701 and the available sizes are not listed on the DTD website, so if you would like to place an order for a set please send us a PM and we'll make sure you're taken care of. Don't forget - DTD also mounts and road force balances all tire and wheel packages for no additional charge and right now a new set of Method Race Wheels qualify for $50.00 OFF INSTANTLY :cool:
What is the MR701?
Method Race Wheels is proud to announce the release of their all-new Trail Series MR701 wheel, set to hit the market late summer 2018. The 701's no-nonsense eight spoke design is the perfect option for those looking to get away from the popular simulated beadlock styling. With one-piece 356 aluminum construction and T6 heat treatment, the 701 is exactly what you've been looking for to hit the trails
Among many features, the all new patent-pending Bead Grip ® Technology is the most exciting. Found on both the inner and outer bead seat, strategically placed grooves are designed to engage with the tire bead for increased grip while running lower tire pressures. In addition to the grooves, the 'safety hump' has a more aggressive profile which further stabilizes the tire bead in the seat.
Bead Grip® technology aims to be the bridge between a conventional street wheel and a beadlock, which is often not legal for highway use. Reducing air pressure in the tire increases traction and ride quality while on the trail. The ability to safely run lower pressures without having to worry about the tire de-beading along with DOT approval will undoubtedly be a bonus to off road enthusiasts.
Below is a cutaway of a tire bead on the 701 where there is clear engagement with the bead seat and the Bead Grip grooves. To the left the aggressive 'safety hump' is further preventing the tire from de-beading and instantly going flat.
A high number of wheel failures revolve around the inner lip due to its distance from the mounting pad and spokes making it responsible for sustaining heavy loads without much support. To combat this, we've taken the reinforced inner lip design from our race wheels and applied it to the 701. Load ratings are 2650 lbs for 5 & 6 lug applications and 3640 lbs for 8 lug.
The 701 will include a newly designed snap-in center cap for 5 & 6 lug applications and a push-through option for 8 lug with the same texture.
Sizes offered include 15x7, 16x8, 17x7.5 and 17x8.5 with applications for Subarus and Sprinter vans as well as most trucks, Jeeps & SUVs. Finishes include Method Bronze and Matte Black.
What is the weight of the 17x8.5? I’m looking at options for drag setup for my 17 gen 2. Was looking at the the race star 17x9.5 with Mickey Thompson et street r 315/50-17. But these wheels are a little cheaper and don’t look too bad, would be better if they were a bit wider but the tires I’m looking at should still fit. Could you make a package deal for these wheels and the mickeys? Thanks
Thank you for reaching out, magyar86! The 17x8.5 MR701 weighs 31.53 lbs.
Shoot us a PM with the delivery zip code and we'll be happy to provide you with a total out the door price :cool:
We appreciate the opportunity!
No 18s?
Not at this time; 17-inch only for 6-135 fitments.
Dang the race stars are 20.5 lbs! Still these will still make a really nice drag wheel setup. I still would like a quote. Zip code is 77510.
PM sent.
1 - 6 of 6 Posts
