1 - 20 of 350 Posts
Hey guys,
We recently signed on as a forum sponsor and we are very pleased to be a part of this awesome community. Although new to the F-150 platform, we are very familiar with the 4-cylinder line of Ford EcoBoost engines. Our newest EcoBoost development project involves R&D for a performance intercooler for 3.5L trucks. Follow the progress of our team on our blog or posted within this thread!
Ford F-150 EcoBoost Performance Intercooler 2011-2014 | Mishimoto Engineering Blog
Feel free to follow up with any questions about our company, process, or other projects we are working on!
Cool Air for the EcoBoost. F-150 Intercooler R&D, Part 1: Factory Cooler Evaluation
The EcoBoost (EB) engine series is quite impressive and packed full of amazing technology. Direct injection and efficient turbochargers have contributed significantly to improved fuel mileage without compromising engine output. Our fleet of shop vehicles currently includes two EB-powered vehicles, a Fiesta and a Mustang. Both models thoroughly impressed our team with their power, drivability, and handling. We developed a ton of new products for the 1.6L, 2.0L, and 2.3L. Now it is time to turn our attention to the V6 EB world. Our first target is a performance intercooler for the 11-14 3.5L F-150.
From our experience with other EcoBoost models, the factory intercoolers are not exactly ideal. The Mustang heat-soaks after a few pulls, and both hot hatches will quickly exceed the intercooler efficiency with a couple easy modifications. Although the factory F150 intercooler is comparably more stout than the coolers for the smaller 4-cylinder models, many have still found it to be inefficient during repeated pulls or when towing heavy loads. So, with that in mind we have a couple of goals with our cooler design that should provide some really nice benefits for your truck.
Efficiency Improvement
The primary goals for intercooler development are always to improve efficiency and drop intake temperatures. These are the primary functions of the charge-air-cooler. Although the factory intercooler is adequate for some trucks, many folks with modified EBs are finding that the factory coolers just don’t cut it. The ability of these engines to gain power is almost laughable; increasing output over 450 wtq is a few simple modifications away. With that in mind, you’re going to want an intercooler that can handle the additional heat generated by greater output.
The factory intercooler features a tube-and-fin core, which is essentially a standard among OEM coolers. Below is an image of the external fins and tubes on the factory cooler.
Factory Ford F150 EcoBoost intercooler core
This core type is inexpensive to manufacture. Compared to other cores, the tube-and-fin allows airflow to pass through the core with less restriction. Where this core suffers is in efficiency and heat-soak prevention.
Our prototype will feature a large bar-and-plate core, which will result in greater heat transfer and lower intake temperatures, and it is far less prone to heat-soak. For most of our new intercoolers in development, this is the type of core we will use.
We won’t just throw a core together. Our team will be strategically designing the internal fins, external fins, and bar sizes to maximize flow. In addition, we will be conducting comparison testing to determine efficiency against the factory cooler.
More on this in future segments!
Durability
The factory cooler utilizes plastic end tanks to route airflow from the piping through the core. From our previous experience with a variety of vehicles, plastic isn’t a great choice. It does provide for a smooth flow internally, but the reliability and durability of plastic in this environment is questionable. At higher boost levels, crimp connections that attach the core have failed. Over time and through countless temperature oscillations, plastic will weaken and can rupture.
Aluminum is a more robust material choice and eliminates any chances of failure from high boost pressures and/or high temperatures. Our counterpart intercooler will feature cast-aluminum end tanks. By casting the tanks we can strategically design the internal surface to attain maximum flow through the core.
Condensation Issues
Many EB owners have reported stuttering and CELs related to condensation buildup within the intercooler. Reports show this to be a result of over-efficiency in cooling the air, as well as CCV-related problems. Ford issues a TSB for installation of a deflector to prevent this, but it hasn’t been effective in all cases. Although not optimal, one common solution is to drill a small weep hole in the base of the cooler to allow condensed fluid to escape. This modification, along with the addition of a catch can and new spark plugs, seems to solve most issues. We will keep this in mind with our design, and we might possibly offer a solution for draining any fluid that might make its way into the cooler.
Factory Cooler Initial Evaluation
F150 Intercooler development test vehicle
We rolled our test vehicle into the shop and got to work removing the factory cooler. Before designing a counterpart of our own, we needed to capture information and dimensions from the factory unit.
The EB models have a good deal of space under the hood. Plastic components litter the engine bay, but this is to be expected in a new vehicle.
F150 Intercooler development test vehicle engine bay
The front grille features an interesting array of heat exchangers. The Ford F150 EcoBoost intercooler is mounted on the lower portion and uses its own grille inlet for airflow.
Below is a look through the lower duct for the intercooler.
Ford F150 EcoBoost intercooler duct
Check out a shot showing the mounting position and angle of the factory cooler.
After these observations, we removed the factory cooler so we could take a closer look at the components, features, and core size.
Ford F150 EcoBoost intercooler removed
F150 intercooler removed
Coming Up – Factory Cooler Full Evaluation
Next time we will be taking a close look at all the components and features of the factory intercooler. In addition, we will record the dimensions and select a core size and orientation.
Thanks for reading!
-John
Good write up, Thread subscribed.
Nice article. My biggest beef with intercooler location is lack of being able to run a winch in the bumper. The full race and on3 performance have filled this roll how is yours going to mount?
Nice article
Thanks for taking a look Rocky!
Thanks for the kind words. We should have an additional update in the next few weeks.
Interesting, I don't believe we had considered winch mounting locations. I will definitely pass this on to the engineer tackling this project. Thanks for providing this input!
Thanks
-John
X2 Winchested, I would prefer to see another option for relocating the CAC up behind the grille. It seems to help with the condensation buildup in the intercooler since the CAC its self isn't the lowest point.
To be cost competitive and attract those who want the simplest install possible, the stock location will be more attractive. That being said, there are already many options available.
An additional option mounting the intercooler higher up in front of the radiator is more attractive in my opinion, as there is more airflow for cooling the intercooler. Most everyone says the factory radiator still does a good job of maintaining engine coolant temps. Also as others had stated, a winch, lights, etc can be mounted in that location without interference with the intercooler and no concerns with reduced airflow to the intercooler.
Full Race is the only "brand name" company that makes the second variation, and On3 is the only "knock-off" that makes that variation. If you could make it look different than Full Race so the cry babies dont whine about it (you know who you are :p ), and make it cost competitive, then I think you guys are on to something. Obviously back it with some quantitative results i.e. flow at X pressure delta, pressure drop at X boost, IAT reduction with repeated pulls, etc
Definitely subscribed. Have heard of you guys in the subi world and its all good. I've seen great products you've made. Looking forward to it. My 2 cents. Kinda gotta choose bt upper mount typically more expensive for better results or lower easy install for lower price. I don't think you can do both. Looking forward to results
Steve
2014 Ford F150 XLT Crew Cab EB
If it's anything like the Wagner and cheaper, I'd be in!
Pardon my ignorance, but what is the widget with the small wiring harness shown next to the large port on the driver side in this picture?
I recently removed my intercooler for inspection and cleaning and didn't see anything like that?
On the 13-14 there is a e-BOV. That widget thing your taking about is the e-bov The 11-12 don't have it. That's why when you get an aftermarket intercooler make sure you get it for your exact year.
Ahhhh... Thanks!! 6-weeks into EcoBoost ownership, still learning every day!!
Discussion Starter #13
Sounds like we need to make a tough decision. We have heard of a few complaints regarding the factory radiator and its inability to keep the EB cool in very hot climates. Placing the cooler in-front of this heat exchanger may only further reduce efficiency. That being said, it sounds like we could achieve some impressive CAC efficiency and also reduce condensation buildup.
Definitely passing this on to our team for some further discussion/evaluation.
Thanks for the input/recommendations guys, this is very helpful.
Steve
Thank you Steve! Yes, we are very involved with the Subaru community and have been developing parts for the WRX/STi for quite some time. Thanks for following our progress.
Thanks Gremlin! Obviously we are a bit far from completion, so pricing is not nearly concrete at the moment. I can assure you it will be a great value.
Thanks for checking out our thread!
Thanks SS! We are designing an intercooler for direct fitment on the 13-14 models. We can then easily adapt our design for the early models which lack the BOV.
Thanks
-John
Discussion Starter #14
Quick update guys!
Cool Air for the EcoBoost. F-150 Intercooler R&D, Part 2: Initial Design Work
After taking a brief look at the factory cooler and components, we needed to begin the design for our counterpart. This will involve the use of both modern and conventional tools to ensure that our prototype meets all our requirements.
Factory Intercooler Features
Factory F150 intercooler
The factory intercooler pulled from our test vehicle came with the upper shroud that Ford had added to help prevent condensation issues. It also included a couple mounting pegs which use grommets for isolation.
The rear of the cooler reveals two inlets, one outlet, and the electronic bypass valve (BPV) unit found on the 2013 and 2014 models.
We removed the BPV unit and inspected the connection point. We would need to replicate this with our design to provide bolt-on fitment.
Factory F150 intercooler bypass valve
On this cooler, the two inlets are a simple push-on and clamp-style connection. The outlet is a quick-disconnect. We will be emulating this connection in our design, so obtaining precise measurements is important.
After inspecting the quick-connect, we found it to be similar, though not identical, to that of the Ford 6.7L Powerstroke CAC connection. We will need to model a new quick-connect for this cooler.
Factory Cooler Dimensions
We need our intercooler to bolt up to the vehicle in a manner similar to the factory piece. We don’t want our customers cutting, drilling, or grinding anything if it can be avoided.
We set the stock cooler on our CMM (coordinate measuring machine) to capture mounting points, sizing, and feature dimensions.
Factory F150 intercooler on CMM table
Prototype Core Sizing
We also needed to get an idea of the core size for our prototype, which requires some test fitting. For this process, we often use hardened foam to put together a general shape or size. This foam material is easy to cut and makes the process relatively quick.
Foam for F150 EcoBoost Intercooler mockup
We completed our basic shape after making several cuts.
Prototype F150 EcoBoost intercooler core
The metal strapping was added to provide some additional rigidity for our test fit. Once the shape was refined, we placed the prototype in the truck to check fitment.
Prototype F150 EcoBoost intercooler core installed
As you can see, we’ve opted to locate the cooler in the same position as the factory unit to take advantage of airflow from the lower duct. Moving the cooler to the upper portion of the grille would restrict airflow to the radiator and transmission coolers. Such a restriction would have an impact on efficiency in certain driving situations.
We are planning to increase the core volume significantly. This, along with a strategically designed core, should result in some nice improvements in intake temperature.
Coming up – 3D Models
Our engineering team is putting together some 3D models of our initial design so we can start creating a functional prototype (or two) for testing purposes. Check back soon for a neat update!
Thanks for reading!
-John
I'm glad I held out on an aftermarket CAC. Looking forward to the 3D models and a finalized design!
Would be nice to see a kit that eliminates all the lengthy stock charge plumbing.
But looks like you guys are taking a logical, methodical, and sound engineering approach (I'm a Mechanical Engineer myself). Looking forward to your CAD images and some test data.
Discussion Starter #18
Me too keep it up guys
Thanks for the kind words guys!
-John
Mishimoto 3.5L Performance Intercooler R&D
Someone needs to design a dual core setup. That would eliminate some piping.
1 - 20 of 350 Posts
