I have two sets of fittings that appear to possible be used for the inlets to the turbo inlet pipes. One set is barbed on both ends. The other set is threaded on one end. Which ones should I be using. The instructions say to drill a hole one size smaller than 3/8"; this would tell me to use the barbed fittings. But is the barb a tight enough seal?
TIA
TIA
