Been doing some upgrades.
Wanted to powder coat calipers, you have to take them completely apart, pistons, seals etc to do so(no idea how to get new seals for calipers or put back together) and shops still don't like to do them due to liability. It also takes a lot of cleaning of old ones to get right. So I chose to buy brand new OEM and paint with G2. I bought new bracets too and painted those as well.
For brakes I did some research. I had the bad vibration even after turning the stock rotors. I eneded up going with R1 Concepts rotors and posi quite ceramic brake pads. Found these being used on the raptor forum quite a bit and got a really good deal through a vendor there.
1. Heres the information provided about the R1 rotors. They are supposed to be cast in the UK (not verified) and treated, machined and coated in California. The rotors I got are the "geomet" line which are "op rotor line, G3500 high carbon metallic casting, dissipate heat faster than cast iron, lighter and stronger than cast iron; coated with geomet which Is better than zinc and are lifetime crack resistant." The eline is G3000, "G3000 grade cast iron and zinc coated, same as (stop tech and powerstop?)" and are not as good as the G3500. This is the information provided to me, don't know if 100% true.
2. Posiquite are ceramic made in china. They make FAR less brake dust. It is amazing. I am so happy.
3. Fluid is Amsoil Syn.
4. I sprayed the back of the pads with some red crap from NAPA for noise prevention.
5. I bedded the pads following R1 website. I don't remember the details, you can find there, but it was like 60 to 10 half pedal, 50 to 10 4 times in a row really hard, then 60 to 5 medium, all this back to back. The rotors will be hot and smoking. This is normal.
6. There is not rust on the rotors, with exception of the machined slotted. I think they machined these after they coated them, thus there is no coating here. There is very slight surface rust here.
7. On the new calipers, I also bought brand new copper rings for banjo bolt, caliper bolts, bracket bolts etc. Ford give you 50$ core charge on each caliper when send back. Very good deal. Front caliper bracket bolts are 185ft lbs! Rear is 125? (if i remember right). If you want to torque down anything, do the bracket bolts.
