1 - 2 of 2 Posts
Hey guys, in the next day or two I want to install my 20" light bar down in the bumper in front of the intercooler and am planning on wiring it into the high beams. Where is the best place to tap into the high beam signal wire to run to the switch? Is there a wire in the steering column or under the dash somewhere? Or will I need to tap a wire behind a headlight and run it through the firewall? TIA
I wired my light bar to the high beam at the headlight wiring harness, used it only to trigger the relay. I also set the
light bar with a 3 way switch so it will be turned on either by the high beam or by the switch or left off by the switch.
1 - 2 of 2 Posts
