Diode Dynamics is excited to introduce our new SS3 LED Fog Light Kits for the 2006+ F150!
Watch Overview Video for Type FT SS3 Fog Light Kit for 2011-2014 F150!
Watch Overview Video for Type F2 SS3 Fog Light Kit for 2015+ F150!
You asked for it and we listened! Our
SS3 LED Fog Light Kits are now available for the 2006+ F-150! These bolt-on kits allow you to replace your factory fog lamps with a pair of SS3 LED Pods. Featuring higher output intensity than any other 3” LED pod on the market, our SS3 LED pods have been designed for maximum light output, with custom-engineered TIR optics shining in highly functional beam patterns, all in a compact, durable package.
Focused: Most LED pods on the market, even certain premium options, use outdated technology like reflectors or simple lenses that lose light internally and to glare. By comparison, our custom-engineered total internal reflection (TIR) optic in the SS3 collects all of the light from the LED chips, drastically reducing wasted light and improving total efficiency.
While these outdated optics lose up to 10% of the light output shining through an outer lens, the SS3’s custom-molded TIR optic functions as both the optic and the main lens, dramatically increasing the amount of usable light output.
Check out the 2006-2010 F150 SS3 Fog Light kit here
Check out the 2011-2014 F150 SS3 Fog Light kit here
Check out the 2015+ F150 SS3 Fog Light kit here
Functional Patterns: All
SS3 LED Pod beam pattern options were designed with optical simulation modeling, to shape the light output in a highly-functional beam pattern. Making it a perfect option for your factory fog location! We offer these kits in two SAE-compliant optics:
- Our SAE Driving optic is designed to supplement your high beams, but it’s great for improving general illumination as well. Rather than a typical "spot" pattern, the Stage Series Driving pattern shines in an 18x8 degree spread, providing just enough width to completely light up the road ahead at high speeds.
- Our SAE Fog optic provides an extremely wide field of illumination, with high-intensity light output over an entire 80-degree spread. It serves as a great upgrade for any factory foglamp, and will fully illuminate the area in front of your vehicle. Choose your output color of 6000K cool white or 3000K selective yellow, which is popular for cutting through inclement weather.
*Please check your local laws and regulations for aiming, installation, and applicability.
White or Yellow: Our
SS3 LED Pods are available in your choice of 6000K cool white or 3000K selective yellow. The white is a 6000K color temperature, which is a true white output, without any blue, and is a perfect match for most OEM LED lights. The selective yellow is a 3000K color temperature, great for high contrast in poor weather or a totally unique look on the road.
Sport or Pro: Stage Series LED Pods are available at two different power levels. Both the Sport and Pro options use high-intensity LED emitters, and TIR optics for unmatched focus and overall output. However, the Pro option is double the amount of total power!
Plug-and-Play Installation: These kits feature bolt-on installation, meaning they require no cutting, drilling, or permanent modification! Both our
Type FT Kit for the 2006-2014 F-150 and our
Type F2 Kit for the 2015+ F150 include a custom-engineered bracket and bezel for a clean, factory-style appearance.
Each kit will include:
- Two (2) 3” SS3 LED Pods
- Two (2) 9006 DT Adapters
- Custom-engineered mounting brackets and bezel
- All necessary hardware
See how to install our SS3 Fog Light Kit on a 2011-2014 F150 below!
Customizable: If you’re looking to change the output color, add a layer of protection, or simply add some extra style to your SS3 LED pods, our snap-on
covers are a great option. Like our scratch-resistant SS3 lenses themselves, the
SS3 Pod Covers are made with a strong polycarbonate plastic, to protect against whatever the road throws your way.
Owner: @velocityblue_fx4 on Instagram
Proven Reliability: Our SS3 LED Pods have been extensively tested for long-term operation from -40 to 185 degrees F, along with vibration, moisture intrusion, and corrosion testing. All of these tests are completed to SAE standards, just like OEM components!
If you have any questions, please don't hesitate to post, PM, or email
[email protected].
Thanks for looking,
Collin O.
Diode Dynamics
