1 - 20 of 1435 Posts
Discussion Starter · #5 ·
Yes they have been working on thus tube for a while now and is only 16 pounds of boost :)... They said its more than 200ft pounds over stock and 150hp over stock. I'm super excited.. And that's only stage 2 tune they have a stage 3 for water meth/nitrous
2012 F150 EcoBoost Lariat
Holy Guacamole!
That is a whole lotta power!
Wow, now that is a torque monster! Must be a good tune to use when towing.
Discussion Starter · #9 ·
Yea mpt is Assn awesome company they have put shot of r and d into this tune. And the tq is the the roof. I'm loading to tune onto my programmer now
It says 22.5 psi on the graph? From what i've seen, boost that high is past the efficiency map on our turbos. I'm not trying to be a debbie downer either I just suggest you datalog your tunes and check the knock for sure just for the safety of your engine. Congrats on the new tunes.
Holy cow....ive never seen numbers that high to the wheels before with just a tune..that's nuts. Congrats! Might have to switch from LMS if those tunes are safe.
Discussion Starter · #13 ·
Yea read that article i posted they are pretty serious
Discussion Starter · #14 ·
Went to my local 1/8th mile track today. Its not timed just run what you got heads up.. Beat out 3 dodge Cummins semi built, a supercharged 2006 f150, 2012 Chevy silveraldo 6.2, Ford lightning :) and a focus st full bolt ons from Cobb.. I was very impressed
I just got in line for the update.... :cool:
Discussion Starter · #17 ·
You will be very impressed.. Not really a good tune got gas mileage. If you push the tow haul button it shifts sooner and is a less aggressive Trans setting. I was running in Manuel mode and shifting by myself for better fuel economy
Actually, I got their tune in mid July, so it'll be interesting to compare the previous version to this newer revision.
Discussion Starter · #19 ·
Oh ok cool.. You like that one so far?
Power was great, but the shift strategy needed some work.
It shifted weird, to me, a bit.
It would sometimes surge at parking lot speeds.
Sometimes it would downshift with a WOT pedal input, and then hold that gear if you immediately got back out of it.
Not a deal killer, by any stretch of the imagination, but made me a bit nervous to run it all the time. I switched back and forth between it the SCT canned tunes. Have a week or so on the SCT tunes, and a week or so on the MPT Tune.
