Is it a motorcraft t stat?
unfortunately not, and i herd motorcraft doesnt make a 180° tstat i think?Is it a motorcraft t stat?
I have not had a temp spike which would lead me to or have a concern of an air pocket, and i installed the tstat yesterday afternoon never checked the temps after install till the drive to work this morning cause i left my tuner at the house like a dingdong. As for the tstat being faulty thats what im leading towards cause its a motorad brand and i had this issue before on my old vehicle it didnt last longRunning those temps, especially after a procedure that requires the coolant loop to be opened (dumped), would have me suspecting air pocket.
Or as Justinjs might be asking, a faulty thermostat.
Alright im gonna try and burp the system since i didnt do that and see what happens and if it continues to be a problem ill put the oem tstat back inView attachment 175826 \
This is from a summer 80+ degree day. Once up to temp mine runs 199-205 degrees F. It is in a light weight under 4500 pound 2wd F150.
OEM thermostat coolant was changed earlier in the summer and system flushed.KM
Mine was also motorad and it was 208-221 normally. A few weeks ago I exchanged it for a new motorcraft one and it sits at 188-190 all day.I have not had a temp spike which would lead me to or have a concern of an air pocket, and i installed the tstat yesterday afternoon never checked the temps after install till the drive to work this morning cause i left my tuner at the house like a dingdong. As for the tstat being faulty thats what im leading towards cause its a motorad brand and i had this issue before on my old vehicle it didnt last long
Honestly not sure, maybe look around or call the stealership and see if they could order one.unfortunately not, and i herd motorcraft doesnt make a 180° tstat i think?
Yeah the tstat is bad wont even open at all, so im putting in a new motorcraft and not messing with the system any more not worth the riskMine was also motorad and it was 208-221 normally. A few weeks ago I exchanged it for a new motorcraft one and it sits at 188-190 all day.
Im running 200-207 with the new one, wonder if i can get better temps by disabling the grill shutter with forscan if it can be doneMine was also motorad and it was 208-221 normally. A few weeks ago I exchanged it for a new motorcraft one and it sits at 188-190 all day.
Yes i spent 30mins burping the systemAre you sure it's burped well ?
I herd of that part number but someone said that it was not a 180° tstat but i will take your word for it and see what i come up with. There was a bumch of coolant that cameout with the tstat and with the history i had with the brand im not gonna take anychances a motor is to expensive to take a chance on a cheap partHaving to replace your stat yet again would suck, but Motorcraft does make a 180 stat for these - RT1225, available from RockAuto for about $23. I'm running one (haven't even had my tune adjusted for it yet, so the fans still don't come on until higher temps) and it works as claimed. Opens at 180, full open at 188.
Burping these things isn't a time thing. It's a number of events thing. If you don't have a vacuum system, you'll need to monitor the level in the bottle for a few weeks. I'd bet money you didn't get every single pocket out.
Just bought one two weeks ago and installed it myself. It was stamped 180F, and the ECT/CHT temps I'm seeing on the cluster and via my Livewire back that up.I herd of that part number but someone said that it was not a 180° tstat but i will take your word for it and see what i come up with. There was a bumch of coolant that cameout with the tstat and with the history i had with the brand im not gonna take anychances a motor is to expensive to take a chance on a cheap part
Did you buy the tstat from the dealer or rockauto? Im taking your word on it but i looked it up and it Pops up as a 190° and 180° temp. And what wrong with the orange coolant?Just bought one two weeks ago and installed it myself. It was stamped 180F, and the ECT/CHT temps I'm seeing on the cluster and via my Livewire back that up.
And yes, you'll lose a ton of coolant when you pull the stat - honestly, that's how I do coolant changes. Just make sure to dry the belts off before you crank the truck back up. And this is a perfect time to move to MC Yellow coolant if you're still running that orange junk.
