Upload the vid to utube and then post the "share" link in a post here.
I have the same noise. Going to get it checked.New to the forum...I have a 2018 F150 with the 3.5 ecoboost with roughly 42k miles. It's been extremely cold here in the midwest and my truck has recently started making this rumbling noise and can't seem to find any similar noises searching the webs. Thought maybe someone here could help me out. It happens about 5 times after shut off no matter if it's cold or warm about 20-30 seconds part. It also happens sometimes if it's been setting and I just open the door. I have a video but not sure how to upload. Thanks for the help!
It cycles for 3 seconds every 10-40 seconds until the fob is 20 feet away and the door is closed. I have an appointment with Ford tomorrow to take a look. It'll be piece of mind at the least. Thanks for your input.
curious what you find out… as snake mentioned. Once the system reaches adequate pressure, the pump should not run. Could be a leak causing pressure drop, bad pressure sensor (but then you’d hopefully also see a code or have driveability issues.)I don't think your fuel pump should be running continuously. It should "prime" as you say, and then shut off as the pressure switch meets it's expectation.
At least many vehicles are setup like that oem.
