You make some interesting points. I think back to the many throttle bodies and intakes I saw on LS motors. Rarely did I see much if any oil deposits inside the intake or on the TB. I do remember one blower LS motor that had some rather large deposits but never saw any on turbo LS motors. I wonder if any technicians on here see any actual deposits in the TB or intake.There are some really high dollar boosted engines offered by the elite auto manufacturers. It would be a negligible cost to add a catch can with a solenoid that self emptied back into the crankcase via the valve cover to these ultra high dollar engines. Do the twin turbo BMWs do this? Do the supercharged Mercedes Benzs do this? Does any auto manufacturer do this to any engine they offer at any price? Catch cans are for racecars. Sure they can be employed by 'street' cars and will keep the engine from ingesting small amounts of oil but understand that your engine was designed to operate the way it came to you from the manufacturer. If the amount of oil it ingests caused a problem it wouldn't have went into production until that problem was remedied.
I owned an SVT Lightning before this Ecoboost. When the Lightning owners started putting catch cans on their trucks they unknowingly starved the rotors in the supercharger for oiling. Superchargers started failing and showing excessive amounts of wear on the rotors. Ford's design was for the oil that circulated through the intake via the PCV be used for the supercharger rotor lube. The minute amount of oil that made it past and ingested by the motor was well within the design parameters of the engine and caused no problems. It was a good idea to clean the intake track every so often. I cleaned mine at 100k miles. I noticed no difference in performance before and after the cleaning. My truck gave me admirable performance for 166K miles. For a boosted engine that made 100's of 1/4mile passes and served as a daily driver I dare not complain. I'd still be in that truck had I not purchased a boat to big for it to tow. For every factory system you omit, modify, or replace there will be unseen/unadvertised repercussions. Do your research and find out as much as you can before hand. Some of these repercussions are harmful some are actually beneficial.
Take into consideration that oil will reduce your intercoolers efficiency, i.e. higher intake temps, reduced power. This is all food for thought for anyone willing to read this.
I was ready to see the gains from cleaning 100k miles of residuals from my intercooler, intake, & intake track. I went to the track after I cleaned the system and ran the same mid 13s that the truck always ran in the given air temps. Everything was cleaner but it didn't amount to any performance gain.It was a good idea to clean the intake track every so often. I cleaned mine at 100k miles. I noticed no difference in performance before and after the cleaning.
It's just some more cleverly disguised spam, that's all. If you look at the OP's posting history and him selling one of these snake oil contraptions in the Buy/Sell/Trade section it becomes apparent.What's a cool can?
This information coming from someone who is trained and in the profession should carry some weight. I'd bet your son can also verify that engines produce more blow by as the boost is turned up. Once the factory system of controlling crank case pressure is overwhelmed it becomes beneficial to employ additional means of controlling those pressures and the additional oil they can carry through the system.I gave a call to my son who is a master technician. He got that working for Ford and Chevrolet until the dealership he worked for closed. He now is a master technician for Toyota. He did work for Ford the first year the eco boost came out. After reading all this stuff I just decided to give him a call. I talked with him about this and in a nutshell here is what he told me. He worked with the eco boost motor (which he really thinks a lot of) as well as aftermarket motors with turbos in his "side job" at a performance shop. He told me he opened up many TB's and intakes at Ford for various reasons and never saw any deposits other than a thin film of oil within the TB on trucks that did a lot of towing. He was familiar with the concept and did actually see two vehicles that had what he called "homemade catch cans". He said there was a very small portion of oil deposits but that usually came from aerosolized oil blow by that usually doesn't even reach the TB. His opinion was it was a "driver peace of mind thing" that really was not that necessary unless you planned to do a ton of towing. He did say the LS motor if driven hard will tend to make small deposits in the TB but a rag gets rid of them pretty easily. He also said back when he was with Ford that the dealer had control of most warranty work up to a cost point at which time you had to call in a Ford rep to evaluate. He thinks that has really changed though where Ford is much more involved. He said Toyota has to see every warranty request and frequently they must take pictures and send them to Toyota. He also said with Toyota you better not even use a larger tire than stock or they will turn down the claim. He said they were real "hard asses" about an alteration in the vehicles they sell.
I generally call it like I see it. You posts had the classic telltale sign of a spammer. If your posts weren't spam please accept my appology.Crab balls, The rest of the story. I bought the can because I thought it was the right thing to do, after more research I decided not to install it. Some owner still think they needed it. I'm only trying to recoup my investment. If you read my post # 41 maybe you wouldn't be so quick to judge!
I would like to point out that I was a professional independent mechanic working primarily on older Mercs, BMW's and Porsche's for 2 years before I was an aircraft mechanic. Since I have been turning wrenches on all of the 29 cars I have owned thus far. I am very qualified on this topic as well. Now granted I don't have a working knowledge of the Ecoboost specifically, but I have been working on turbo'ed engines for years now. Also to your point about premium car companies not running catch cans on their car from the factory, that really comes down to federal emission regulations. We wouldn't even have a PCV system if it weren't for the Feds and EPA. Trying to get a catch can to pass by Federal regulators is tough, just getting an engine through it tough, so why complicate it with adding something like a catch can if they can just deal with the "side effect" through the dealers? Its a logistical issue. I prefer to run one on my truck just because that's what I have done on most of my turbo'ed cars. It is/can be personal preference. I choose to do it.This information coming from someone who is trained and in the profession should carry some weight. I'd bet your son can also verify that engines produce more blow by as the boost is turned up. Once the factory system of controlling crank case pressure is overwhelmed it becomes beneficial to employ additional means of controlling those pressures and the additional oil they can carry through the system.
Its always a choice. You are doing what you feel comfortable with for the reasons you see fit. I have no problem with that. Don't get the info I provide confused with me attempting to tell anyone what to do. Hey its YOUR truck and you should do what you see fit to do with it.I would like to point out that I was a professional independent mechanic working primarily on older Mercs, BMW's and Porsche's for 2 years before I was an aircraft mechanic. Since I have been turning wrenches on all of the 29 cars I have owned thus far. I am very qualified on this topic as well. Now granted I don't have a working knowledge of the Ecoboost specifically, but I have been working on turbo'ed engines for years now. Also to your point about premium car companies not running catch cans on their car from the factory, that really comes down to federal emission regulations. We wouldn't even have a PCV system if it weren't for the Feds and EPA. Trying to get a catch can to pass by Federal regulators is tough, just getting an engine through it tough, so why complicate it with adding something like a catch can if they can just deal with the "side effect" through the dealers? Its a logistical issue. I prefer to run one on my truck just because that's what I have done on most of my turbo'ed cars. It is/can be personal preference. I choose to do it.
Only time will tell if there are any. The example I gave with the SVT Lightnings is the type of thing that jumps up and bites you in the ass. Ford spent millions in research and development of these engines and did the best they could to cover all the bases. I'd be willing to bet that none of their testing involved a catch can so we really don't have any knowledge of what the long term effects will be. Possibly no bad would come from it, probably no gain to be had either. How many times did they empty the catch can in the torture test? If THAT engine didn't need a catch can then no stocker should.I expect this discussion could go on forever. Let me ask the question of what negative draw backs or repercussions could come from running a catch can other than the obvious warrant issues ?
All good points. I know a catch can is a big deal in the corvette community and I never saw much oil deposits with the few vettes that didn't have a catch can except perhaps a thin film on TB's but just about everyone that does any modification with a vette has put one on . Of course a lot of those folks I found also had a TB spacer and we all know how worthless those are.Only time will tell if there are any. The example I gave with the SVT Lightnings is the type of thing that jumps up and bites you in the ass. Ford spent millions in research and development of these engines and did the best they could to cover all the bases. I'd be willing to bet that none of their testing involved a catch can so we really don't have any knowledge of what the long term effects will be. Possibly no bad would come from it, probably no gain to be had either. How many times did they empty the catch can in the torture test? If THAT engine didn't need a catch can then no stocker should.
