1 - 4 of 4 Posts
I have. 2012 3.5 and I’m consuming about half a qt of oil every 3ish weeks I don’t have a visible oil leak and no smoke coming from exhaust period The only thing I can see is my driver side turbo has more oil build up around the boots then passenger side truck runs fine over all. Is this normal? I don’t remember losing oil before but I could be in my head
Sounds like you have checked the turbo and engine, follow the turbo outlet to the intercooler, could be losing some at the joint. Other than what you mentioned the only other place you could be losing it is at the head gasket back into the coolant system. How's the coolant reservoir looking? It will just be way off color, level will be high, but it will dump through the overflow
1 - 4 of 4 Posts
