1 - 5 of 5 Posts
So I'm ordering the parts to replace the manifold on each side of my 2015 Ecoboost XLT Sport as at least the passenger side has been leaking for more than a year (I know I know)..
Anyways I just want to make sure I'm ordering everything I should need.. And if there's any special tools I'll need to do this, please let me know! I have most basic tools as I work on my own dirt bikes and do construction. This will be my first time doing something like this on a truck, so any advice is welcome! Also installing a 4 inch rough country lift this weekend myself, so that'll be fun lol.
I plan on ordering these 2 kits from BDDIESEL..
Is there a cheaper way to do this? I tried looking around but it seems like this is the best option price wise.. Also, is there anything else these kits are missing that I need to order as well??
Thanks for any help!
Haven't done it myself yet, I have BD Manis on standby but would've gone with the latest OEM manifolds if I had known.
So they only advice I have for now, after reading other people's experiences with this job is:
  • Plan to also replace the water and oil lines going into the turbos, as well as the fittings at the turbo.
  • Maybe plan the lift kit install for another weekend.
Check these posts for more:
Reactions: Boatwaco
Just did mine and used the same parts, I had a shop do it, I did turbos too and it was just too much money in parts for me to learn on. And I didn't want to risk running into an issue and having my truck immobile in my driveway. It looks like you did your research and have it figured out though. I am happy with the result. Since you are in there and it has to come off anyways, you could also do a set of turbo adaptors between the turbo exhaust outlet and the downpipes, it's just one extra restriction you can remove in the exhaust system. I honestly can't tell you if any 1 part made a difference because I pretty much did the whole exhaust starting at the block.
1 - 5 of 5 Posts
