1 - 18 of 35 Posts
Casedoublex
Discussion starter · #1 ·
I have a 2018 F-150 2wd with 2.7l ecoboost, after I installed new brakes and one caliper(passenger rear)
I drove it and everything seemed fine, I got in it one morning it started drove fine I went in the store and came back out to find it not shift into gear and Park Brake function limited message on dash does anybody have any idea what could be going on?
Discussion starter · #5 ·
As of the moment no but I was looking at maybe getting a v linker and use forscan to see what was going on but at the moment can’t read codes the only thing I have is a obd2 scanner
Discussion starter · #7 ·
Yes I replaced the rear passenger caliper and when I had got in it at the store to get it home I had to take the column apart and pull the safety switch out for shifter to get it home and if I put it in and out of maintenance mode it makes the air gap for brake on both side of I use emergency brake everything seems to work fine it’s just now the message on dash and not letting me shift into gear
Discussion starter · #16 ·
You don't have an auxiliary braking system on this truck right? In other words... you don't tow it behind a motorhome that controls an auxiliary braking system.
You could try disconnecting the battery for a few minutes and jumpering the cables together in order to reset everything. I would want to try and pull codes before getting to that point though. You are going to need a code reader or someone that can pull codes to see what it says.
Wish I could be more help. Hopefully others here with more knowledge will chime in.
And no it’s just what came with the truck as far as the brakes. And thanks for the info and trying to help
1 - 18 of 35 Posts
