1 - 2 of 2 Posts
Hi guys,
Been chasing an intermittent hoot noise that I think has been coming from my drivers side turbo for a while. Lots of testing done and some parts swapped with marginal improvements. Today I may have found a very small hole at the collar area of the tubing feeding the boost pressure to the wastegate and I am very curious if this could at times leak out just enough to cause that wastegate to close prematurely causing what I believe to be compressor surge. Either way, I expect this to be a cheap and fairly simple fix but not having luck finding the actual part number - or a corresponding spec for bulk tubing. Any help would be appreciated. Picture below to demonstrate - sorry for the bad quality. Tear looks to be right in the break of the ink.
No picture is loaded up.
AFAIK you cannot buy just the WGs from Ford. But I believe you can get a set of Turbosmarts. I went and replaced my WG hoses with fuel line from the auto parts store and I am havine zero issues. It does not look as nice though lol
1 - 2 of 2 Posts
About this Discussion
1 Reply
2 Participants
Envious
F150 Ecoboost Forum
Full Forum Listing
